I was wondering if it was possible to use libraries like
this in C programs for the CE?
I'm kinda thinking not for this particular one, since it uses floats, but maybe it can be edited to not use floats?
And Mateo, if you answer this, can you do it without being condescending,if it is possible
Try it. Theoretically it should work.
Okay! I will attempt to do so when I get home from work.
Would I have to not use the floats?
Also, should I cut out unused functions from it to save space?
Floats should also *theoretically* work. And ZDS does appear to be dumb and compile in unused functions, so it may be worth it to delete them or disable them with preprocessor conditionals.
Okay, awesome! I am excited to try this out
No.
The question is why on earth are you using that library. You most certainly do not need it.
I don't know,I was researching better ways to handle collision in top down games in C and that library was one of the things I found. I'm not necessarily going to use it, I was just wondering if it was possible
And if you think that one is so bad, do you have any alternative suggestions?
:0
I have never seen that in the header, but i guess I'm just blind
