So I was wanting to use the ScaledSprite(PTR_IN, PTR_OUT) function in an ice program. I defined a sprite, but then instead of declaring a blank sprite, I just made one manually (allocated sprite area in bytes plus 2) because I forgot to do it the other way. It didn't work this way, but when I corrected myself later and used a blank DefineSprite, it did work. I am just wondering, what is the difference between what I did, and what DefineSprite does?
*what I did*
DefineSprite(4,4,"...data...")->A
Alloc(66)->B
8->*{B}
8->*{B+1}
ScaleSprite(A,B)
det(0)
det(57,A,0,0)
det(57,B,160,0)
det(1)
the second one doesn't display
You either need to fix the code yourself or provide more code, as it works properly with my randomly-made sprite + 2x enlarged:
It's just a copy-paste from CEmu's memory visualizer, I'm sorry for the grey edges
Here is a programm named “A“
iB
DefineSprite(4,4,“... Data...“)→A
DefineSprite(8,8)→B
det(82,A,B)
det(0)
i normal sprite
det(57,A,5,5)
i scaled sprite clip
det(57,50,50)
i scaled sprite noclip
det(62,A,80,80,2,2)
Pause
det(1)
Maybe this can help you Smile
For what you need to do, you should be able to just define A and run the det(62) line to display the second sprite. Try like this?
iB
det(0)
i normal sprite
det(57,A,5,5)
det(62,A,80,80,2,2)
Pause
det(1)
iB
det(0)
i normal sprite
det(57,A,5,5)
det(62,A,80,80,2,2)
Pause
det(1)
iB
det(0)
i normal sprite
det(57,A,5,5)
det(62,A,80,80,2,2)
Pause
det(1)
