My son got caught in a downpour with his calculator in his backpack. It had water under the screen but seemed to dry out OK. However, whenever he turns off the calculator, the screen stays on (all white pixels).
I ran diagnostics and everything looks OK except maybe the RAM test (I'll explain shortly).
I reflashed the OS to make sure it wan't a software problem. What's interesting when the calculator is connected to the PC is that when I turn it off, I can hear the USB connection being dropped by Windows (an audible beep is made when establishing and breaking a USB connection). So the calculator thinks it is being shut off, but the LCD isn't complying.
So I never ran the diagnostics before, but the RAM test may be showing an issue. When I run it, the words "Testing RAM..." are shown. If I run the test not connected to the PC, the words slowly fade out but the screen stays on. I think the RAM is supposed to turn off the calculator, so this behavior may be as expected. The calc is off when the words are gone (but the screen is still white).
When I run the test connected to a PC (charging), the words "Testing RAM..." stay black and displayed on the screen. I don't think the calc is off since pressing ON does not turn it on. If I disconnect the USB then the words dim again slowly until gone, and pressing ON turns the cal back on again. In both cases, the test shows as green as if it passed.
So something is preventing the screen from turning off. Any suggestions? I ordered some tools so I can take it apart and look around next.
