Hey guys, I'm writing a program, which has a settings menu, which saves your choices to an archived custom list. However, if they have not used my program before, they will get an ERROR message, as it is an invalid variable. Ways to see if they have used program?
- jcgter777
- Super-Expert (Posts: 927)
- 15 Oct 2018 05:28:46 pm
- Last edited by jcgter777 on 15 Oct 2018 05:36:07 pm; edited 1 time in total
Store a unique number into a unique list that won't get overwritten. Then check for that number. Bingo!
jcgter777 wrote:
Store a unique number into a unique list that won't get overwritten. Then check for that number/list. Bingo!
I don't think that will work, since if I check for that list, and it doesn't exist, I will get an error message.
Use SetUpEditor MYLST. It will create the list as a 0-element list if it doesn't exist, unarchive it if it exists and is archived, or do nothing if it exists and is unarchived.
EDIT: You should probably also SetUpEditor (with no arguments) afterwards to restore the list editor to editing the default L₁-L₆.
Reading the TI_Basic Dev Wikidot page about that command, it will get you an ERROR: ARCHIVE if it is archived, rather than unarchive it.
Incorrect.
they may be archived, or they may not even exist. You can deal with both of those individually: storing to the dimension will create the list if it didn't exist, and the UnArchive command will move the list to RAM if it wasn't there.
However, if you're wrong about the list, both of these commands will cause an error. If the list exists but is archived, storing to its dimension will cause an ERR:ARCHIVE error. If the list doesn't exist, unarchiving it will cause an ERR:UNDEFINED error. Sounds like a vicious circle.
The keyword here is both. It's referring to Archive and Unarchive.
The SetUpEditor command allows you to deal with both of these problems at once. Say the program saves its data in LSAVE. Use the SetUpEditor command on it, and from then on you know that the list exists AND that it is unarchived.
As stated, the SetUpEditor command resolves this by unarchiving the list if it is, indeed, archived.
Incorrect.
Oh I misread that, thank you for pointing it out.
- rohanmodi
- Member (Posts: 107)
- 15 Oct 2018 06:06:20 pm
- Last edited by rohanmodi on 15 Oct 2018 06:12:40 pm; edited 1 time in total
I keep getting a syntax error when using SetUpEditor in a program.
I'm using it like this:
SetUpEditor DECI,DEGR
Edit: I still get error even after separating the lists.
IIRC you can't put two together like that. And maybe you need the small L in front, but I don't think so.
Also, please refrain from double posting within 24 hours. There's an edit button for a reason
EDIT: I meant double posting before someone else posts
. Good effort, though.
Try adding the small L in front of the names. (Found in catalog)
It seems right, though.
Edit: I tried the L, it does now work, thank you so much.
Strange... the small L is usually not needed, an you can put as many lists as you want to in the SetUpEditor. I can't think of why not using the L would error, I never use the L in SetUpEditor, so you might want to see if there was any extra white/blank spaces? (although that's probably not why...)
It is in the list menu... which is a lot easier to get to than finding it in the Catalog.
I know this is an old thread, but rather than creating a new one on the same topic, I decided to just post in this one.
I had an idea for making the program run a particular section of code once if it was the first time the program was used: putting a custom list in the program download. The list would hold a special number that would be altered after the program ran once.
However, I didn't know first, if was a good idea to add lists to the program download, and second, if it would make transferring the files to calc harder. Are these valid concerns, or is it just a preference?
I think it is not user friendly and you should instead create the list in your program, which can be done using the SetUpEditor command (see Runer112's post).
