I tried using onblock for my 84 plus CE. It will not work.
May help if you read the program thread.
TheLastMillennial
- Official Cemetech Cake Manager (Posts: 1991)
- 10 Sep 2018 05:44:47 pm
- Last edited by TheLastMillennial on 10 Sep 2018 05:47:04 pm; edited 1 time in total
The thread says exactly that it wont, and can't work. The OS was changed making the program completely useless for new OSes. You'll have to downgrade your OS to below (I think) OS 5.2 if you want it to work.
There's no way to fix the program for the most recent OS.
EDIT: Well I'm mostly correct, I missed the part about GetKey messing up OnBlock.
Mateo wrote:
I would just like to point out that with TI being cool and updating OSes, OnBlock for the CE no longer works if you use any sort of getkey routine. Sorry about that Razz
FYI, ONBLOCK doesn't block the on button when you just run it. 1 has to be in Ans. You can either execute "1", then ONBLOCK, or 1:Asm(prgmONBLOCK or 1:prgmONBLOCK if you have OS 5.3 or later.
Hope this helps! (To disable, just run it again, but with 0 in Ans.
- jcgter777
- Super-Expert (Posts: 927)
- 13 Sep 2018 07:24:46 pm
- Last edited by jcgter777 on 13 Sep 2018 07:38:15 pm; edited 1 time in total
Are you sure they aren't asm programs? Those don't break when you press on.
Then I don't know what's wrong.
PRO TIP: Use the edit button on your post, instead of double posting. Double posting within 24 hours is generally looked down upon.
Cesium (in the CE archives under asm/shells) has a password ability. It's also very nice. Be sure to read its ReadMe!
Just fyi, @ mentions don't do anything on this forum.
The shortcuts aren't working probably because you never activated them. Like the readme says, press [mode] while on the Cesium main screen. Then turn on 'enable keypad shortcuts'.
And sorry of those <kbd></kbd>'s get in the way. Those were my ideas . They look better on GitHub though.
» Goto page 1, 2 Next
Page 1 of 2
