I need to round in ice to display an approximation of some points. But this is not implemented. Is there any way to?
TheLastMillennial
- Official Cemetech Cake Manager (Posts: 1991)
- 15 Jul 2018 04:10:02 pm
- Last edited by TheLastMillennial on 15 Jul 2018 04:26:12 pm; edited 1 time in total
You could take say 123456789 and if you want to round it to the nearest 100th you could divide by 100, (so you'd have 1234567 ) then multiply by 100 to get back up to 123456700. Be warned ICE just chops off the decimals so don't expect great rounding from this.
Maybe PT_ has a better way than this. You can try digging around the docs more.
EDIT: Nope, Womp had the better way, also jcgter had a good idea too
- mr womp womp
- Official Cemetech Cat Manager (Posts: 1781)
- 15 Jul 2018 04:15:51 pm
- Last edited by mr womp womp on 16 Jul 2018 03:04:59 pm; edited 3 times in total
What TLM suggested above is known as truncating, which is not the same as rounding. Since ICE does have the remainder() command, you can round to the nearest nth like this:
(Where X is the number you want to round) is just a standard manual rounding.
I don't think ICE supports treating booleans as integers, but in pure basic, you could do something like this:
Which of course wouldn't be needed because you have the round() command but I'm just saying..
if remainder(X,n)≥(n/2)
X+n→X
X-remainder(X,n)→X
X+n(remainder(X,n)≥n/2)-remainder(X,n→X
You can do what TheLastMillennial said for any number and any value. If you want to round to the nearest 10th, divide by ten and re-multiply, et cetera. This will work until the next version of ICE is released, since then floats will be added.
A slow way is to keep subtracting 1 until it's divisible by your rounding number, but I don't actually know if you can check for remainders in ICE. If you want to, you can also subtract 1 until the last numbers are the last numbers of what you want. 12345 - 1(45) = 12300, and you can check the last two digits by some extra tedious code.
The best thing to do is to post in the ICE compiler thread for a feature request: ADD ROUNDING.
if remainder(X,n)≥n
Then
X-remainder(X,n)+n→X
Else
X-remainder(X,n)→X
for n would you'd type in the number you want it rounded to?
Jcsq6 wrote:
if remainder(X,n)≥n
Then
Else
X-remainder(X,n)→X
yes, like if you want it to the nearest 8th, you would put 8
I completely agree, although the round() command is usually used with decimal numbers, so PT_ might actually include it in an upcoming update along with dceimal numbers
This is already a feature that PT_ is planning to add, as seen here.
