Please post any useful ASM routines here, citing the original author if it isn't you. Follow the format.
Wow, that worked! Thanks for the help, Tari. For anyone else, here's the routine.
RunBASICProgram
Originally made by Dan E. Bugfixes and optimizations by Kerm Martian. This routine allows you to run BASIC programs from an App.
Inputs
Op1 = name of variable to parse [eg program to run]
You also need to define three bytes of saveRAM, homeSaveA (1 byte) and homeSaveHL (2 bytes).
Outputs
Program is parsed and run. Any homescreen hooks present before the routine are called are restored.
b = 0 for an error, errorcode otherwise.
Destroyed:
All
RunBASICProgram
Inputs
Outputs
Destroyed:
All
_SetHomeHook equ 4FABh
_ClrHomeHook equ 4FAEh
apiFlg2 equ 41
sysHookFlg equ 52
appInpPrmptInit equ 0
appInpPrmptDone equ 1
appWantHome equ 4
_saveCmdShadow equ 4573h
_saveShadow equ 4576h
_rstrShadow equ 4579h
cmdExec equ 6
cmdFlags equ 12
cxExtApps equ 058h
RunBASICProgram:
in a,(2)
rla
sbc a,a
out (20h),a
xor a
ld (HomeSaveA),a
bit appWantHome,(iy+sysHookFlg)
jr z,NoHookToSave
ld hl,(9B8Ch)
ld (HomeSaveHL),hl
ld a,(9B8Eh)
ld (HomeSaveA),a
NoHookToSave:
in a,(6)
ld hl,HookAddr
bcall(_SetHomeHook)
set progExecuting,(iy+newDispF)
set cmdExec,(iy+cmdFlags)
AppOnErr(ErrorHandler)
bcall(_ParseInp)
AppOffErr
xor a
ErrorHandler:
push af
bcall(_ReloadAppEntryVecs)
res progExecuting,(iy+newDispF)
res cmdExec,(iy+cmdFlags)
pop bc
FinishCont:
push bc
bcall(_ClrHomeHook)
bcall(_ForceFullScreen)
res AppWantHome,(iy+sysHookFlg)
pop bc
RestoreHookStuff:
push bc
ld a,(HomeSaveA)
or a
pop bc
ret z
push bc
ld a,(HomeSaveA)
ld hl,(HomeSaveHL)
bcall(_SetHomeHook)
set AppWantHome,(iy+sysHookFlg)
pop bc
ret
HookAddr:
add a,e
cp 3
ret nz
bit appInpPrmptDone,(iy+apiFlg2)
res appInpPrmptDone,(iy+apiFlg2)
ld b,0
jr z,FinishCont
ld hl,appvecs
bcall(_AppInit)
or 1
ld a,cxExtApps
ld (cxCurApp),a
ret
appvecs:
.dw dummyret
.dw saveshad
.dw putway
.dw rdisp
.dw dummyret
.dw dummyret
rdisp:
bcall(_RstrShadow)
dummyret:
ret
saveshad:
bcall(_SaveShadow)
ret
putway:
xor a
ld (currLastEntry),a
bit appInpPrmptInit,(iy+apiFlg2)
jr nz,aipi
bcall(_ClrHomeHook)
aipi:
bcall(_PutAway)
ld b,0
jr RestoreHookStuff
