Is there a way to rotate a sprite or move the legs of the sprite without having to create many different sprites?
Sure, but only if you're using ICE v2.0 (if you didn't already). Check out FlipSpriteX and similar commands, something like det(64) and upwards. This little piece of code will flip a sprite:
Currently you have to type out the det( commands though, because SC is temporarily downgraded to ICE v1.5, but hopefully that will be fixed soon.
Hope this helps!
DefineSprite(16,16,".....")->OLDSPRITE
DefineSprite(16,16)->NEWSPRITE
RotateSpriteC(OLDSPRITE,NEWSPRITE)
Hope this helps!
Hope this helps!
Hope this helps!
Is the code you gave me for version 1.5. If I have version 2, do I just use flip sprite?:
This only works within ICE v2.0. Stop using v1.5, and switch to v2.0 if you didn't already.
There are 5 commands to rotate sprites:
- FlipSpriteY
- FlipSpriteX
- RotateSpriteC
- RotateSpriteCC
- RotateSpriteHalf
You can even rotate and scale them at the same time, but that's a little bit harder.
- FlipSpriteY
- FlipSpriteX
- RotateSpriteC
- RotateSpriteCC
- RotateSpriteHalf
- FlipSpriteY
- FlipSpriteX
- RotateSpriteC
- RotateSpriteCC
- RotateSpriteHalf
- FlipSpriteY
- FlipSpriteX
- RotateSpriteC
- RotateSpriteCC
- RotateSpriteHalf
Ok thanks, I do in fact have version 2
