- Muessigb
- Advanced Member (Posts: 236)
- 23 Feb 2018 07:50:45 pm
- Last edited by Muessigb on 23 Feb 2018 08:22:07 pm; edited 1 time in total
SM84CE wrote:
yeah, no floats as of now, all #'s are 24 bit, iirc
Yes, they are using 16 and 24 bit (according to the datasheet).
Muessigb wrote:
coolcrab123 wrote:
MateoConLechuga wrote:
coolcrab123 wrote:
That'd be why i'm asking if there's a work around...
*That would be why I'm asking if there is a workaround...
No. You can simulate fractions with integers though.
I need to get this old pc to automatically capitalize stuff.
I don't need to simulate fractions, I need to check them in an if statement when I'm trying to convert a decimal to binary code
There are no floating point variables I think. All maths is going to be integer math.
At least this was the case with Axe back on the monochrome calculators.
There is also the signed vs unsigned and 8 vs 16-bit question.
I was absent for a while and have not kept track of the new additions to Axe nor have I really looked into ICE but I guess similar restrictions apply.
But can someone maybe think of a method to use the Fpart( function without Fpart( with other Basic Commands because I don't see one due to the inability to use the Round( function either
You can simulate fractions with integers. One integer holds the fractional part, the other holds the integer part. We can help you with specific implementations of various things, but there is no "one fix" or solution.
EDIT: Read Runer's link: https://meta.stackexchange.com/a/233676/287804
How did you Know???
Can someone make a Decimal-->Binary converter without the Fpart( or int( or Ipart( functions, because I don't have time to think of one, I will in turn supply them with a beta when I'm done, and Will add them as a co-author.
What an Offer... ^^
You keep ignoring our suggestions.
We are trying to help you by giving you tips, but you keep telling us to write your code for you.
Nobody is going to write your code for you.
Support the community by joining MyCalcs for free! Co-founder of TI-Toolkit.
Decimal to Binary:
I=1:B=0
While N
R=remainder(N,2)
N=N/2
B=B+R*I
I=I*10
Wow that was so difficult
I don't need code, I need a suggestion on what commands I can use together to simulate the Fpart and iPart commands, where are the suggestions that you are saying I have been given, what you are giving me is supportive commentary, but nobody has answered the question at heart. I'm asking a question and getting a different answer (no offense). The only possible answer that was suggested was to use variables to simulate fractions, but I kindly stated that this would not work for me, because the fractions aren't the important part, the If statement checking for the fractional part is.
BTW: Can someone suggest a work around for this process , if my variable that is being converted to Binary cannot contain a fractional portion and is an integer. (would I still require the Fpart command)
one up time: In ICE (if this helps
Input <binary number>
Disp pi<binary number>
//Input 100 as binary number
Disp π100 //displays 4
- coolcrab123
- Advanced Newbie (Posts: 58)
- 23 Feb 2018 08:29:27 pm
- Last edited by coolcrab123 on 23 Feb 2018 08:31:48 pm; edited 1 time in total
Decimal to Binary:
I=1:B=0
While N
R=remainder(N,2)
N=N/2
B=B+R*I
I=I*10
Wow! Wait, is this compatible to ICE, since ICE has an overly special tendency to over do things (Why did they have to make different key codes...)
There is no fractional part since your variables are 24 bit integers.
I don't need code, I need a suggestion on what commands I can use together to simulate the Fpart and iPart commands, where are the suggestions that you are saying I have been given, what you are giving me is supportive commentary, but nobody has answered the question at heart. I'm asking a question and getting a different answer (no offense). The only possible answer that was suggested was to use variables to simulate fractions, but I kindly stated that this would not work for me, because the fractions aren't the important part, the If statement checking for the fractional part is. ₁
Exactly! But since i divide the length by 2, there may be a fractional part if it's odd.
that, I know, but the other way around.
- MateoConLechuga
- Official Cemetech Lettuce Manager (Posts: 3888)
- 23 Feb 2018 08:36:43 pm
- Last edited by MateoConLechuga on 23 Feb 2018 08:37:58 pm; edited 1 time in total
Probably not, it's just puesdo code. An ICE implementation might look like this, with the number in N and the result in B: (untested)
Decimal to Binary:
0->B+1->I
While N
remainder(N,2->R
N/2->N
B+R*I->B
I*10->I
And because a string's length Cannot be a fraction
- coolcrab123
- 23 Feb 2018 08:39:56 pm
- Last edited by coolcrab123 on 23 Feb 2018 08:43:07 pm; edited 1 time in total
Decimal to Binary:
0->B+1->I
While N
remainder(N,2->R
N/2->N
B+R*I->B
I*10->I
I need to extract the result to a string, is I, the value of each character?
- Muessigb
- 23 Feb 2018 08:40:31 pm
- Last edited by Muessigb on 23 Feb 2018 08:42:13 pm; edited 1 time in total
Yes, but all division is always rounded down to the next integer.
So there cannot be a fractional part. Use modulo to get the remainder after division.
Page 2 of 3
