Degrees divides the circle into more manageable integers that I find easier to manipulate. To put this into perspective, I'd bet imagining one degree without electronics would be easier and more accurate than imagining one radian.
PT_ wrote:
Pi makes more sense:
In that case, yes. I still feel like both should be used, where they are best.
Radians are still a useful thing, though. And they are actually very natural measurements. In fact, the derivative of sin(x) is equal to cos(x) if and only if x is expressed in radians. For degrees, it's much uglier.
Also PT_, there is a natural factor of 1/2 when looking at area, as compared to angle measurement. In fact, in general, the volume of any n-sphere is the surface area of that n-sphere times the radius and divided by the dimension. What's so special about 2 dimensions that it has to cancel the 1/2?
I had an idea: If tau was a calculator token of same size as pi, you would most likely save space in a program.
Yeah! Someone write an OS!
In many cases, yes. Now to work out how to create that token
...no, seriously, someone work that out, at least for one calc model.
One could, at the top of every program, do 2pi→T, and use T as tau.
That's usually what I do. But a tau token would be nice, and that usually ends up wasting space because I lately haven't used the variable enough to compensate in the program
prgmTrouble wrote:
The variable would be a bit slower too, for obvious reasons
Yeah. Just estimate tau to be 6 and you'll be all hex'd up!
No, if you create a separate tau token, it would be the same speed as pi, since the value is not calculated with a formula, but directly stored in the OS.
He said variable. You said token.
Two different things.
iPhoenix
- friendly neighborhood site admin (Posts: 1934)
- Or, do "(pi/tau)^(-1)"
- 14 Mar 2017 06:28:41 pm
- Last edited by iPhoenix on 14 Mar 2017 06:31:57 pm; edited 2 times in total
New rule for this thread: Never use "two" or "2" or some other manifestation of that. Instead, do "τ/π"
(jk)
(jk)
(jk)
Clearly, _iPhoenix_ prefers "tau over pi".
ReGuess wrote:
(jk)
(jk)
Or, do "(π/τ)⁻ยน"
I'm gonna just link this here and let y'all decide for yourselves: https://en.wikipedia.org/wiki/Particular_values_of_the_Gamma_function
- mr womp womp
- Official Cemetech Cat Manager (Posts: 1846)
- 14 Mar 2017 06:32:10 pm
- Last edited by mr womp womp on 14 Mar 2017 06:39:14 pm; edited 2 times in total
0x26!
Or even better...
Imma just drop stirling's formula for approximating the gamma function right here.
Or even better...
mr womp womp wrote:
0x26!
OMG it's perfect. If only it was next to pi on that chart!
Page 2 of 5
