- hp39gii dimgrob, grob editor created.
- 06 Dec 2016 07:36:37 am
- Last edited by ScottZilogZ80fan on 08 Dec 2016 09:34:20 am; edited 4 times in total
Im having problems with dimgrob(G1,list)
How do i define a block say 8*8 ive entered many different parameters
And failed... i know about dimgrob(G1,x,y,c) i have the prime grob Creator,
But it doesn't work on hp39gii... i think you are correct about dimgrob not working on the hp39gii...
i've been writing some more programs, if you copy and paste them to your calculator, you may find the ► character needs to be deleted and retyped, due to a translation error.
that program defines and draws a tile of blocks, it defines its own block,
the next program just tiles a user defined block stored in M2,
If you get an error run the top program to create M2.
this next program is GrobEd, a 16x16 grayscale block editor, create your own block,
and then run Tile() to view it,
use cursor keys and number keys 0,1,2,3 for different greys...
feel free to use any of this code, i dont mind...
to insert a matrix into a program go to the home screen type M2 press enter, press shift-copy, then copy the current edited line and then paste it into your program...
EXPORT Tile()
BEGIN
[[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3],[0,3,3,3,3,3,3,3,3,3,3,3,3,3,0,3],[0,3,0,0,0,0,0,0,0,0,0,0,0,3,0,3],[0,3,0,3,0,3,0,3,0,3,0,3,0,3,0,3],[0,3,0,0,3,0,3,0,3,0,3,0,0,3,0,3],[0,3,0,3,0,3,0,3,0,3,0,3,0,3,0,3],[0,3,0,0,3,0,3,0,3,0,3,0,0,3,0,3],[0,3,0,3,0,3,0,3,0,3,0,3,0,3,0,3],[0,3,0,0,3,0,3,0,3,0,3,0,0,3,0,3],[0,3,0,3,0,3,0,3,0,3,0,3,0,3,0,3],[0,3,0,0,3,0,3,0,3,0,3,0,0,3,0,3],[0,3,0,3,0,3,0,3,0,3,0,3,0,3,0,3],[0,3,0,0,0,0,0,0,0,0,0,0,0,3,0,3],[0,3,3,3,3,3,3,3,3,3,3,3,3,3,0,3],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3],[3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3]]►M2;
RECT_P(3);
DIMGROB_P(G1,16,16,3);
FOR X FROM 1 TO 16 DO
FOR Y FROM 1 TO 16 DO
IFTE(M2[X,Y]<0 OR M2[X,Y]>3,3►M2[X,Y]);
PIXON_P(G1,X-1,Y-1,M2[X,Y]);
END;END;
FOR X FROM 0 TO 15 DO
FOR Y FROM 0 TO 7 DO
BLIT_P(G0,(X*16),(Y*16),(X*16)+16,(Y*16)+16,G1);
END;END;
FREEZE;
END;
EXPORT Tile()
BEGIN
RECT_P(3);
END;END;
END;END;
FREEZE;
END;
EXPORT GrobEd()
BEGIN
1►S;1►T;
RECT_P(3);
RECT_P(X*6,Y*6,(X*6)+5,(Y*6)+5,M2[X,Y]);
PIXON_P(G0,X+128,Y+16,M2[X,Y]);
END;END;
8►X;8►Y;
WHILE 1 DO
0►W;0►V;
IF ISKEYDOWN(9)==1 THEN 0►V;−1►W;END;
IF ISKEYDOWN(10)==1 THEN 0►W;1►V;END;
IF ISKEYDOWN(14)==1 THEN −1►V;0►W;END;
IF ISKEYDOWN(15)==1 THEN 1►W;0►V;END;
GETKEY►N;
X+V►X;Y+W►Y;
IFTE (X<1,1►X);
IFTE (X>16,16►X);
IFTE (Y<1,1►Y);
IFTE (Y>16,16►Y);
IF ISKEYDOWN(47)==1 THEN 0►M2[X,Y];END;
IF ISKEYDOWN(42)==1 THEN 1►M2[X,Y];END;
IF ISKEYDOWN(43)==1 THEN 2►M2[X,Y];END;
IF ISKEYDOWN(44)==1 THEN 3►M2[X,Y];END;
RECT_P(X*6,Y*6,(X*6)+5,(Y*6)+5,0);
WAIT(0.1);
IFTE(X≠S OR Y≠T,RECT_P(S*6,T*6,(S*6)+5,(T*6)+5,M2[S,T]));
PIXON_P(128+S,16+T,M2[S,T]);
X►S;Y►T;
END;
END;
