After reading a quick instructable similar to this project, I drew up a schematic with the same idea except it (hopefully) combines 4 inputs into one channel and then switches that between two outputs.
Now, the following schematic was the one drawn up in the instructable, which I assume works.
I want to make this, but I want to combine 4 audio inputs instead of having just one. I drew this up:
All I did differently was combine the audio sources of all 4 channels and use that as one audio source for the selected output.
Now, I don't know much about how audio inputs operate, but I feel like this won't work because of the method in combining audio channels. So, if I am incorrect, I would appreciate some guidance in what I need to add to make this work.
