Once again, this program is a host driver, and you want a device driver for your program. This code could only be used for programs which use the USB port to interface with devices, not hosts.
I'm working on an OS and probably need USB for some kind of bootloader. Otherwise, sending a larger OS image will be a pain. I can't wait to see this work. Hopefully, it'll be better documented than FreeOS, which I have successfully decoded
It should be listed as a "USB Type A Mini OTG Adapter" or similar. They are fairly inexpensive online, so I recommend getting one if you are at all interested in USB stuff for the CE.
Yeah, it is just a simple USB A Female to USB Mini B Male dongle. Most of the ones you will find online will work, but you just need to make sure it is a data conversion cable as well, rather than just a charging adapter between USB A and USB mini B.This is a good and decently priced (considering the free shipping) dongle that I have used for my Nintendo 3DS and should work with the TI-84 Plus CE.
- LAX18
- Power User (Posts: 403)
- 21 Oct 2018 07:33:41 pm
- Last edited by LAX18 on 22 Oct 2018 05:49:01 am; edited 1 time in total
Well, the protocol is not designed yet, but eventually... perhaps.
EDIT: I should probably also say that it is unlikely that a Wifi USB dongle is ever supported as the power that it would draw could be potentially greater than what the CE supplies over USB.
I'm working on connecting a CE to IRC using a raspberry pi and my serial driver. At this point the only thing preventing this is the software on the pi, which should be relatively easy to finish once I get Python installed.
Also, it might be possible to use a USB Ethernet adapter to directly connect to a network, but I haven't looked into it much.
Work is underway for usbdrvce, fatdrvce, and srldrvce. Stay tuned on the 'usbdrvce' branch of the toolchain
Oooooh this is exciting. I can't wait to see what I can do with it!
What happened to the source code link? It seems like the Github repository has been deleted.
It's all been moved to the toolchain branch.
I see, thanks!
The links are broken- is the code/program still available somewhere? Can you please relink it? I would love to be able to use this.
It's in here.
It will be its own library, like graphx or fileioc.
You can find the header for it at https://github.com/CE-Programming/toolchain/blob/usbdrvce/src/usbdrvce/usbdrvce.h
You can also build that toolchain branch yourself if you want to try it or the FAT driver out now, though it looks like most of it hasn't been implemented yet.
» Goto page Previous 1, 2
Page 2 of 2
