To clarify, I have a TI-84+ but am not able to put 30 KB of programs onto a calculator that only has 24 KB of accessible RAM. Of my total of 17 programs, 4 of them take up just under 24 KB. If someone could help me with the optimization that would be great. The one skill that I'm not very good at is using loops like "For(" and "While". If someone could help me with the Optimization, that would be great. I apologize if my code is messy, I'm a beginner and the TI Connect CE studio does not allow tabs for indentation. I could take some components out if I need to, I would just like to have it all. I know this is a lot but thank you in advance if anyone is able to help.
1. 5985 KB
Degree
Lbl 0
ClrHome
Menu("CALCULATE:","INTERIOR ANGLE",11,"AREA",12,"VOLUME",13,"SURFACE AREA",14,"EXIT",99)
Lbl 99
Stop
Lbl 11
ClrHome
Disp "REGULAR POLYGON:"
Disp ""
Disp "HOW MANY"
Input "SIDES? ",N
If fPart(N)≠0 or N≤2
Then
ClrHome
Disp ""
Disp ""
Disp ""
Output(2,5,"INVALID")
Stop
Else
(180(N-2))/N→X
ClrHome
Disp "SIDES="
Output(1,7,N)
Disp ""
Disp "EACH INTERIOR"
Disp "ANGLE="
Disp ""
Output(4,7,X)
Output(5,7,"DEGREES")
Stop
Lbl 12
ClrHome
Disp "HOW MANY"
Input "SIDES? ",N
If fPart(N)≠0 or (N≤2 and N≠1)
Then
ClrHome
ClrHome
Disp ""
Disp ""
Disp ""
Stop
Else
If N=1
Then
Menu("SHAPE:","CIRCLE",18,"ELLIPSE",19,"EXIT",99
Lbl 18
ClrHome
Input "RADIUS=",R
R*R→R
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(1,1,"AREA=")
Output(3,2,"π*")
Output(3,4,round(R,4))
Output(4,3,"OR")
Output(5,2,round(πR,4))
Output(3,10,"SQUARED")
Output(4,11,"UNITS")
Stop
Lbl 19
ClrHome
Disp "LENGTH OF"
Input "MAJOR AXIS=",A
A/2→A
Disp ""
Disp "LENGTH OF"
Input "MINOR AXIS=",B
B/2→B
AB→R
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(1,1,"AREA=")
Output(3,2,"π*")
Output(4,3,"OR")
Stop
Else
If N=3
Then
ClrHome
Menu("TRIANGLE NATURE:","RIGHT",21,"OBLIQUE",22,"EXIT",99)
Lbl 21
ClrHome
Input "BASE=",B
Disp ""
Input "HEIGHT=",H
ClrHome
Disp "AREA="
Output(1,6,round((BH)/2,4))
Disp ""
Disp " SQUARED UNITS"
Stop
Lbl 22
ClrHome
Input "SIDE a=",A
Disp ""
Input "SIDE b=",B
Disp ""
Input "SIDE c=",C
ClrHome
(A+B+C)/2→S
√(S(S-A)(S-B)(S-C))→A
Disp "AREA="
Output(1,6,round(A,4))
Disp ""
Stop
Else
If N=4
Then
Lbl 98
ClrHome
Menu("QUADRILATERAL:","SQUARE",31,"RECTANGLE",32,"RHOMBUS",33,"TRAPEZOID",34,"KITE",35,"EXIT",99)
Lbl 31
ClrHome
Menu("GIVEN:","SIDE LENGTH",40,"DIAGONAL",41,"RETURN",98,"EXIT",99)
Lbl 40
ClrHome
Input "SIDE LENGTH=",A
ClrHome
Disp "AREA="
Output(1,6,round(A²,4))
Disp ""
Stop
Lbl 41
Input "DIAGONAL=",A
ClrHome
Disp "AREA="
Output(1,6,round(A²/2,4))
Disp ""
Stop
Lbl 32
ClrHome
Input "BASE=",B
Disp ""
Input "HEIGHT=",H
ClrHome
Disp "AREA="
Output(1,6,round(BH,4))
Disp ""
Stop
Lbl 33
ClrHome
Menu("GIVEN:","BASE-HEIGHT",42,"DIAGONALS",43,"RETURN",98,"EXIT",99)
Lbl 42
Goto 32
Lbl 43
ClrHome
Input "DIAGONAL #1=",A
Disp ""
Input "DIAGONAL #2=",B
ClrHome
Disp "AREA="
Output(1,6,round((AB)/2,4))
Disp ""
Stop
Lbl 34
ClrHome
Menu("GIVEN:","BASES",44,"MIDSEGMENT",45,"RETURN",98,"EXIT",99)
Lbl 44
ClrHome
Input "BASE #1=",A
Disp ""
Input "BASE #2=",B
Disp ""
Input "HEIGHT=",H
(A+B)/2→M
MH→A
ClrHome
Disp "AREA="
Disp ""
Stop
Lbl 45
ClrHome
Input "MIDSEGMENT=",M
Disp ""
Input "HEIGHT=",H
(A+B)/2→M
MH→A
ClrHome
Disp "AREA="
Disp ""
Stop
Lbl 35
Disp "
Disp "SIDE WITH OTHER"
Input "LENGTH=",B
(AB)/2→A
ClrHome
Disp "AREA="
Disp ""
Stop
Else
ClrHome
Menu("GIVEN:","SIDE LENGTH",50,"RADIUS",51,"APOTHEM",52,"EXIT",99)
Lbl 50
ClrHome
Input "SIDE LENGTH=",S
(S²N)/(4*tan(180/N))→A
ClrHome
Disp "AREA="
Disp ""
Stop
Lbl 51
ClrHome
Input "RADIUS=",R
(R*R*N*sin(360/N))/2→A
ClrHome
Disp "AREA="
Disp ""
Stop
Lbl 52
ClrHome
Disp "APOTHEM"
Input "LENGTH=",A
A²*N*tan(180/N)→A
ClrHome
Disp "AREA="
Disp ""
Stop
Lbl 13
ClrHome
Menu("VOLUME:","CUBE",101,"REGULAR PRISM",102,"CYLINDER",103,"CONE",104,"SQUARE PYRAMID",105,"SPHERE",106,"RETURN",107)
Lbl 101
ClrHome
S^3→V
ClrHome
Disp "VOLUME="
Output(1,8,round(V,4))
Disp ""
Disp " CUBIC UNITS"
Stop
Lbl 102
ClrHome
Menu("PRISM TYPE:","RECTANGULAR",111,"TRIANGULAR",112,"OTHER",113,"RETURN",114,"EXIT",99)
Lbl 111
ClrHome
Input "LENGTH=",L
Disp ""
Input "WIDTH=",W
Disp ""
Input "HEIGHT=",H
LWH→V
ClrHome
Disp "VOLUME="
Disp ""
Disp " CUBIC UNITS"
Stop
Lbl 112
ClrHome
Disp "REGULAR TRIANGLE"
Disp ""
Disp "SIDE LENGTH OF"
Input "TRIANGLE=",S
Disp ""
Disp "HEIGHT OF"
Input "PRISM="H
(S*S*√(3))/4→B
BH→V
ClrHome
Disp "VOLUME="
Disp ""
Disp " CUBIC UNITS"
Stop
Lbl 113
Disp "AREA OF"
Input "BASE="B
Disp ""
Input "HEIGHT=",H
BH→V
ClrHome
Disp "VOLUME="
Disp ""
Disp " CUBIC UNITS"
Stop
Lbl 114
Goto 13
Lbl 103
ClrHome
Input "RADIUS=",R
Disp ""
Input "HEIGHT=",H
πRRH→V
ClrHome
Disp "VOLUME="
Disp ""
Disp " CUBIC UNITS"
Stop
Lbl 104
ClrHome
Disp ""
Output(3,2,"ENTER ZERO FOR")
Output(4,2,"UNKNOWN VALUES")
Output(8,3,"press enter")
Pause
ClrHome
Disp "RADIUS OF"
Input "BASE=",R
Disp ""
Input "HEIGHT=",H
Disp ""
Disp "SLANT"
Input "HEIGHT=",S
If R>0 and H>0
Then
(πRRH)/3→V
ClrHome
Disp "VOLUME="
Disp ""
Disp " CUBIC UNITS"
Stop
Else
If R>0 and S>0
Then
√(S²-R²)→H
(πRRH)/3→V
ClrHome
Disp "VOLUME="
Disp ""
Disp " CUBIC UNITS"
Stop
Else
If H>0 and S>0
Then
√(S²-H²)→S
(πRRH)/3→V
ClrHome
Disp "VOLUME="
Disp ""
Disp " CUBIC UNITS"
Stop
Else
ClrHome
Disp ""
Disp ""
Disp ""
Stop
Lbl 105
ClrHome
Disp ""
Pause
ClrHome
Input "BASE EDGE=,S
Disp ""
Input "HEIGHT=",H
Disp ""
Input "SLANT HEIGHT=",L
Disp ""
Disp "RADIUS OF"
Input "BASE=",D
If S>0 and H>0
Then
S²→A
AH→V
ClrHome
Disp "VOLUME="
Disp ""
Disp " CUBIC UNITS"
Stop
Else
If S>0 and L>0
Then
S/√(2)→D
√(L²-D²)→H
(SSH)/3→V
ClrHome
Disp "VOLUME="
Disp ""
Disp " CUBIC UNITS"
Stop
Else
If D>0 and H>0
Then
D*√(2)→S
S²→A
AH→V
ClrHome
Disp "VOLUME="
Disp ""
Disp " CUBIC UNITS"
Stop
Else
If H>0 and L>0
Then
√(L²-H²)→D
D*√(2)→S
(SSH)/3→V
ClrHome
Disp "VOLUME="
Disp ""
Disp " CUBIC UNITS"
Stop
Else
If D>0 and L>0
Then
D*√(2)→S
√(L²-D²)→H
(SSH)/3→V
ClrHome
Disp "VOLUME="
Disp ""
Disp " CUBIC UNITS"
Stop
Else
ClrHome
Disp ""
Disp ""
Disp ""
Stop
Lbl 106
ClrHome
Input "RADIUS=",R
(4πRRR)/3→V
ClrHome
Disp "VOLUME="
Disp ""
Disp " CUBIC UNITS"
Stop
Lbl 107
Goto 0
Lbl 14
ClrHome
Menu("VOLUME:","CUBE",111,"REGULAR PRISM",112,"CYLINDER",113,"CONE",114,"SQUARE PYRAMID",115,"SPHERE",116,"RETURN",117)
Lbl 111
ClrHome
6*S²→A
ClrHome
Disp "SURFACE"
Disp "AREA="
Output(2,6,round(A,4))
Disp ""
Stop
Lbl 112
ClrHome
Menu("PRISM TYPE:","RECTANGULAR",121,"TRIANGULAR",122,"OTHER",123,"RETURN",124,"EXIT",99)
Lbl 121
ClrHome
Input "LENGTH=",L
Disp ""
Input "WIDTH=",W
Disp ""
Input "HEIGHT=",H
2LW+2LH+2WH→A
ClrHome
Disp "SURFACE"
Disp "AREA="
Disp ""
Stop
Lbl 122
ClrHome
Disp ""
Input "TRIANGLE=",S
Disp ""
Disp "HEIGHT OF"
Input "PRISM="H
(S*S*√(3))/4→B
2B+(3SH)→A
ClrHome
Disp "SURFACE"
Disp "AREA="
Disp ""
Stop
Lbl 123
Disp "AREA OF"
Input "BASE="B
Disp ""
Disp "PERIMETER OF"
Input "BASE=",P
Disp ""
Input "HEIGHT=",H
PH→A
A+2B→A
ClrHome
Disp "SURFACE"
Disp "AREA="
Disp ""
Stop
Lbl 124
Goto 14
Lbl 113
ClrHome
Input "RADIUS=",R
Disp ""
Input "HEIGHT=",H
πRR→B
2πRH→A
A+2B→A
ClrHome
Disp "SURFACE"
Disp "AREA="
Disp ""
Stop
Lbl 115
ClrHome
Disp ""
Pause
ClrHome
Disp "RADIUS OF"
Input "BASE=",R
Disp ""
Input "HEIGHT=",H
Disp ""
Disp "SLANT"
Input "HEIGHT=",S
If R>0 and H>0
Then
√(H²+R²)→L
πR(R+L)→A
ClrHome
Disp "SURFACE"
Disp "AREA="
Disp ""
Stop
Else
If L>0 and H>0
Then
√(L²+H²)→R
πR(R+L)→A
ClrHome
Disp "SURFACE"
Disp "AREA="
Disp ""
Stop
Else
If L>0 and R>0
Then
πR(R+L)→A
ClrHome
Disp "SURFACE"
Disp "AREA="
Disp ""
Stop
Else
ClrHome
Disp ""
Disp ""
Disp ""
Stop
Lbl 115
ClrHome
Input "BASE EDGE=,S
Disp ""
Input "HEIGHT=",H
Disp ""
Disp "SLANT"
Input "HEIGHT=",L
S²+2S*√((S²/4)+H²)→A
ClrHome
Disp "SURFACE"
Disp "AREA="
Disp ""
Stop
Lbl 116
ClrHome
Input "RADIUS=",R
4πRR→A
ClrHome
Disp "SURFACE"
Disp "AREA="
Disp ""
Stop
Lbl 117
Goto 0
2. 5724 KB
Lbl 0
ClrHome
Menu("PROPERTIES","EXPONENTS",1,"LOGARITHMS",2,"TRIGONOMETRY",3,"EXIT",99)
Lbl 1
ClrHome
Menu("EXPONENTS:","ZERO/NEGATIVE",11,"MULTIPLICATION",12,"DIVISION",13,"PARENTHESES",14,"RATIONAL",15,"RETURN",16,"EXIT",99)
Lbl 11
ClrHome
Disp " 0 "
Disp " (A) = 1 "
Disp " "
Disp "----------------"
Disp " b 1 "
Disp " (A) = --- "
Disp " (A)^b "
Output(8,1,"--press--enter--")
Pause
ClrHome
Stop
Lbl 12
ClrHome
Disp " b c (b+c) "
Disp " A * A =(A) "
Disp " "
Disp " c c (c) "
Disp " A * B =(A*B) "
Disp " "
Pause
ClrHome
Stop
Lbl 13
ClrHome
Disp " "
Disp " b "
Disp " (A) (b-c) "
Disp " ---- =(A) "
Disp " c "
Disp " (A) "
Disp " "
Pause
ClrHome
Stop
Lbl 14
ClrHome
Disp " / b\^c (bc) "
Disp " \(A)/ = (A) "
Disp " "
Disp " / A \^c /A^c\ "
Disp "( --- ) =( --- )"
Disp " \ B / \B^c/ "
Pause
ClrHome
Stop
Lbl 15
ClrHome
Disp " (1/x) "
Disp " (A) = √(A) "
Disp " "
Disp " (b/x) "
Disp "(A) = √(A^b)"
Disp " "
Pause
ClrHome
Stop
Lbl 16
Goto 0
Lbl 99
Stop
Lbl 2
ClrHome
Menu("LOGARITHMS:","1 , 0 , < 0",21,"REARRANGE",22,"SIMPLIFY",23,"NATURAL LOG.",24,"RETURN",16,"EXIT",99)
Lbl 21
ClrHome
Disp " LOG (1) = 0 "
Disp " b "
Disp "LOG (0) LOG (-)"
Disp " b or b "
Disp " "
Disp " =*UNDEFINED* "
Pause
ClrHome
Stop
Lbl 22
ClrHome
Disp " LOG (A)=x "
Disp " b "
Disp " IS THE SAME AS "
Disp " "
Disp " x "
Disp " (B) = A "
Disp "--press--enter--"
Output(8,1,"for--next--page-")
Pause
ClrHome
Disp " LOG (A)=x "
Disp " b "
Disp " "
Disp " (x) "
Disp " (B) = A "
Pause
ClrHome
Disp " LOG (A^c) "
Disp " b "
Disp " = "
Disp " "
Disp " C*LOG (A) "
Disp " b "
Pause
ClrHome
Disp " "
Disp " 1 "
Disp "LOG (A) =-------"
Disp " b LOG (B)"
Disp " a "
Disp " "
Pause
ClrHome
Disp " "
Disp " LOG (A)"
Disp " x "
Disp " b LOG (B)"
Disp " x "
Disp " "
Pause
ClrHome
Stop
Lbl 23
ClrHome
Disp " LOG (A) = 1 "
Disp " a "
Disp "SO: "
Disp " "
Disp " LOG (A^b)= b "
Disp " a "
Pause
ClrHome
Disp " LOG (A*B) "
Disp " x "
Disp " = "
Disp "LOG (A)+ LOG (B)"
Disp " x x "
Disp " "
Pause
ClrHome
Disp " LOG (A/B) "
Disp " x "
Disp " = "
Disp " "
Disp "LOG (A)- LOG (B)"
Disp " x x "
Disp " "
Pause
ClrHome
Stop
Lbl 24
ClrHome
Disp " = 2.7182818284"
Disp " LOG (A)=x "
Disp " "
Disp " x or "
Disp "() =A ln(A)=x"
Pause
ClrHome
Disp "ln(0)= UNDEFINED"
Disp " ln()= 1 "
Disp "SO: "
Disp " "
Disp " ln(^a)= a "
Disp " "
Pause
ClrHome
Stop
Lbl 3
ClrHome
Menu("TRIGONOMETRY:","SINE",31,"COSINE",32,"TANGENT",33,"IDENTITIES",34,"PARENT GRAPHS",40,"RETURN",16,"EXIT",99)
Lbl 31
ClrHome
Disp " "
Disp " OPP "
Disp " sinθ = ----- "
Disp " HYP "
Disp " "
Disp " "
Pause
ClrHome
Disp " 1 "
Disp " cscθ = ----- "
Disp " sinθ "
Disp " HYP "
Disp " OPP "
Pause
ClrHome
Stop
Lbl 32
ClrHome
Disp " "
Disp " ADJ "
Disp " cosθ = ----- "
Disp " HYP "
Disp " "
Disp " "
Pause
ClrHome
Disp " 1 "
Disp " secθ = ----- "
Disp " cosθ "
Disp " HYP "
Disp " ADJ "
Pause
ClrHome
Stop
Lbl 33
ClrHome
Disp " "
Disp " OPP "
Disp " tanθ = ----- "
Disp " ADJ "
Disp " "
Disp " "
Pause
ClrHome
Disp " 1 "
Disp " cotθ = ----- "
Disp " tanθ "
Disp " ADJ "
Disp " OPP "
Pause
ClrHome
Stop
Lbl 34
ClrHome
Disp "sin²θ + cos²θ =1"
Disp "tan²θ +1 = sec²θ"
Disp "cot²θ +1 = csc²θ"
Pause
ClrHome
Disp " sinθ "
Disp " tanθ = ------ "
Disp " cosθ "
Disp " cosθ "
Disp " cotθ = ------ "
Disp " sinθ "
Pause
ClrHome
Stop
Lbl 40
FnOff
FnOn 0
DelVar Y₀
CoordOn
AxesOn
PlotsOff
Radian
ZTrig
ClrHome
Menu("GRAPH:","y=sin(x)",41,"y=cos(x)",42,"y=tan(x)",43,"NEXT",50,"RETURN",3,"EXIT",99)
Lbl 50
ClrHome
Menu("GRAPH:","y=csc(x)",51,"y=sec(x)",52,"y=cot(x)",53,"NEXT",60,"BACK",40,"RETURN",3,"EXIT",99)
Lbl 60
ClrHome
Menu("GRAPH:","y=arcsin(x)",61,"y=arccos(x)",62,"y=arctan(x)",63,"BACK",50,"RETURN",3,"EXIT",99)
Lbl 41
"sin(X)"→Y₀
DispGraph
Pause
ClrHome
Goto 70
Lbl 42
"cos(X)"→Y₀
DispGraph
Pause
ClrHome
Goto 70
Lbl 43
"tan(X)"→Y₀
DispGraph
Pause
ClrHome
Goto 70
Lbl 51
"1/sin(X)"→Y₀
DispGraph
Pause
ClrHome
Goto 70
Lbl 52
"1/cos(X)"→Y₀
DispGraph
Pause
ClrHome
Goto 70
Lbl 53
"1/tan(X)"→Y₀
DispGraph
Pause
ClrHome
Goto 70
Lbl 61
"sin(X)"→Y₀
DispGraph
Pause
ClrHome
Goto 70
Lbl 62
"cos(X)"→Y₀
DispGraph
Pause
ClrHome
Goto 70
Lbl 63
"tan(X)"→Y₀
DispGraph
Pause
ClrHome
Goto 70
Lbl 70
FnOff 0
DelVar Y₀
Degree
ZStandard
Stop
3. 5724 KB
ClrHome
Output(1,1,"FOR TRIANGLE ABC")
Output(2,1,"----------------")
Output(3,1,"A=")
Output(3,6,"ANGLE OF")
Output(4,6,"VERTEX A")
Output(5,1,"----------------")
Output(6,1,"a=")
Output(6,5,"SIDE ACROSS")
Output(7,4,"FROM VERTEX A")
Pause
Lbl 0
ClrHome
Menu("TRIANGLE NATURE:","RIGHT",1,"OBLIQUE",2,"EXIT",99)
Lbl 99
Stop
Lbl 1
ClrHome
Menu("RIGHT TRIANGLE:","SOLVE",50,"SPECIAL CASE",51,"AREA",53,"RETURN",52,"EXIT",99)
Lbl 52
Goto 0
Lbl 53
ClrHome
Input "BASE=",B
Disp ""
Input "HEIGHT=",H
ClrHome
Disp "AREA="
Disp ""
Stop
Lbl 50
Goto 60
Lbl 51
Menu("SPECIAL CASE:","45°-45°-90°",55,"30°-60°-90°",56,"RETURN",57,"EXIT",99)
Lbl 57
Goto 1
Lbl 55
ClrHome
Disp "LEG a="
Output(1,7,"X")
Disp " Angle A="
Output(2,10,"45°")
Disp "LEG b="
Output(3,7,"X")
Disp " Angle B="
Output(4,10,"45°")
Disp "HYP.="
Output(5,6,"X*√(2)")
Stop
Lbl 56
ClrHome
Disp "LEG a="
Output(1,7,"X")
Disp " Angle A="
Output(2,10,"30°")
Disp "LEG b="
Output(3,7,"X*√(3)")
Disp " Angle B="
Output(4,10,"60°")
Disp "HYP.="
Output(5,6,"2*X")
Stop
Lbl 60
ClrHome
Menu("ANGLE UNIT:","DEGREES",3,"RADIANS",4,"RETURN",9,"EXIT",99)
Lbl 3
Degree
90→F
Goto 8
Lbl 4
Radian
π/2→F
Goto 8
Lbl 9
Goto 1
Lbl 8
ClrHome
Disp ""
Pause
ClrHome
Disp "HYPOTENUSE"
Input "LENGTH= ",C
ClrHome
Input "LEG a= ",A
Input "ANGLE A= ",D
Disp ""
Input "LEG b= ",B
Input "ANGLE B= ",E
If A+B>C or E+D>F
Then
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Output(3,4,"DIMENSIONS")
Degree
Stop
Else
If A>0 and (E>0 and E<F)
Then
F-E→D
(A*sin(F))/(sin(D))→C
√(C²-A²)→B
ClrHome
Disp "LEG a="
Output(1,7,round(A,4))
Disp " Angle A="
Output(2,10,round(D,4))
Disp "LEG b="
Output(3,7,round(B,4))
Disp " Angle B="
Output(4,10,round(E,4))
Disp "HYP.="
Output(5,6,round(C,4))
Degree
Stop
Else
If A>0 and (D>0 and D<F)
Then
F-D→E
√(C²-A²)→B
ClrHome
Disp "LEG a="
Disp " Angle A="
Disp "LEG b="
Disp " Angle B="
Disp "HYP.="
Degree
Stop
Else
If B>0 and (E>0 and E<F)
Then
F-E→D
(B*sin(F))/(sin(E))→C
√(C²-B²)→A
ClrHome
Disp "LEG a="
Disp " Angle A="
Disp "LEG b="
Disp " Angle B="
Disp "HYP.="
Degree
Stop
Else
If B>0 and (D>0 and D<F)
Then
F-D→E
√(C²-B²)→A
ClrHome
Disp "LEG a="
Disp " Angle A="
Disp "LEG b="
Disp " Angle B="
Disp "HYP.="
Degree
Stop
Else
If C>0 and (E>0 and E<F)
Then
F-E→D
(C*sin(D))/(sin(F))→A
√(C²-A²)→B
ClrHome
Disp "LEG a="
Disp " Angle A="
Disp "LEG b="
Disp " Angle B="
Disp "HYP.="
Degree
Stop
Else
If C>0 and (D>0 and D<F)
Then
F-D→E
√(C²-A²)→B
ClrHome
Disp "LEG a="
Disp " Angle A="
Disp "LEG b="
Disp " Angle B="
Disp "HYP.="
Degree
Stop
Else
If A>0 and B>0
Then
√(A²+B²)→C
sin((A*sin(F))/C)→D
F-D→E
ClrHome
Disp "LEG a="
Disp " Angle A="
Disp "LEG b="
Disp " Angle B="
Disp "HYP.="
Degree
Stop
Else
If (B>0 and C>0) and C>B
Then
√(C²-B²)→A
(sin((A*sin(F))/C))→D
F-D→E
ClrHome
Disp "LEG a="
Disp " Angle A="
Disp "LEG b="
Disp " Angle B="
Disp "HYP.="
Degree
Stop
Else
If (A>0 and C>0) and C>A
Then
√(C²-A²)→B
F-D→E
ClrHome
Disp "LEG a="
Disp " Angle A="
Disp "LEG b="
Disp " Angle B="
Disp "HYP.="
Degree
Stop
Else
If E>0 and D>0 and A=0 and B=0 and C=0
Then
ClrHome
Disp "LEG a="
Output(1,7," ?")
Disp " Angle A="
Disp "LEG b="
Output(3,7," ?")
Disp " Angle B="
Disp "HYP.="
Output(5,6," ?")
Degree
Stop
Else
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Degree
Stop
Lbl 2
ClrHome
Menu("ANGLE UNIT:","DEGREES",20,"RADIANS",21,"RETURN",22,"EXIT",99)
Lbl 20
Degree
180→G
Goto 10
Lbl 21
Radian
π→G
Goto 10
Lbl 22
Goto 0
Lbl 10
ClrHome
Menu("GIVEN:","SSS",11,"SAS",12,"ASA",13,"AAS",14,"SSA",15,"RETURN",16,"EXIT",99)
Lbl 16
Goto 2
Lbl 11
ClrHome
Input "SIDE a= ",A
Disp ""
Input "SIDE b= ",B
Disp ""
Input "SIDE c= ",C
cos((A²-B²-C²)/(2BC))→D
cos((B²-A²-C²)/(2AC))→E
cos((C²-A²-B²)/(2AB))→F
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(1,1,"a=")
Output(1,3,round(A,2))
Output(1,9,"A=")
Output(1,11,round(D,2))
Output(3,1,"b=")
Output(3,3,round(B,2))
Output(3,9,"B=")
Output(3,11,round(E,2))
Output(5,1,"c=")
Output(5,3,round(C,2))
Output(5,9,"C=")
Output(5,11,round(F,2))
Degree
Stop
Lbl 12
ClrHome
Input "SIDE A= ",A
Disp ""
Input "GIVEN ANGLE= ",F
Disp ""
Input "SIDE B= ",B
If F>G
Then
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Stop
Else
√(A²+B²-(2AB)*(cos(F))→C
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(1,1,"a=")
Output(1,9,"A=")
Output(3,1,"b=")
Output(3,9,"B=")
Output(5,1,"c=")
Output(5,9,"C=")
Degree
Stop
Lbl 13
ClrHome
Input "1ST ANGLE= ",F
Disp ""
Input "GIVEN SIDE= ",B
Disp ""
Input "2ND ANGLE= ",D
If B>G
Then
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Stop
Else
G-F-D→E
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(1,1,"a=")
Output(1,9,"A=")
Output(3,1,"b=")
Output(3,9,"B=")
Output(5,1,"c=")
Output(5,9,"C=")
Degree
Stop
Lbl 14
ClrHome
Disp "ANGLE ACROSS"
Disp "FROM GIVEN"
Input "SIDE=",F
Disp ""
Disp ""
Input "GIVEN SIDE= ",C
If F>G or D>G
Then
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Stop
Else
G-F-D→E
(C*sin(E))/(sin(F))→B
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(1,1,"a=")
Output(1,9,"A=")
Output(3,1,"b=")
Output(3,9,"B=")
Output(5,1,"c=")
Output(5,9,"C=")
Degree
Stop
Lbl 15
ClrHome
Output(2,2,"THERE MAY BE")
Output(3,2,"TWO SOLUTIONS")
Pause
ClrHome
Disp "SIDE ACROSS FROM"
Input "GIVEN ANGLE= ",C
Disp ""
Input "2ND SIDE= ",A
Disp ""
If ((A*sin(F))/C)>1 or ((A*sin(F))/C)≤0
Then
ClrHome
Disp ""
Disp ""
Disp ""
Output(2,3,"NO SOLUTION")
Degree
Stop
Else
If F>G
Then
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Stop
Else
D→Q
G-F-D→E
E→R
B→O
G-D→Z
If (Z+F)>G
Then
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(1,1,"a=")
Output(1,9,"A=")
Output(3,1,"b=")
Output(3,9,"B=")
Output(5,1,"c=")
Output(5,9,"C=")
Degree
Stop
Else
G-F-D→E
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(1,1,"a=")
Output(1,9,"A=")
Output(3,1,"b=")
Output(3,9,"B=")
Output(5,1,"c=")
Output(5,9,"C=")
Output(7,1,"PRESS ENTER FOR")
Output(8,1,"SECOND SOLUTION")
G-D→D
G-F-D→E
(C*sin(E))/sin(F)→B
Pause
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(1,1,"a=")
Output(1,9,"A=")
Output(3,1,"b=")
Output(3,9,"B=")
Output(5,1,"c=")
Output(5,9,"C=")
Degree
Stop
4. 4044 KB
ClrHome
Disp "NO MORE THAN 25:"
Disp ""
Disp "HOW MANY"
Input "NUMBERS? ",Z
If Z≤1 or Z>25
Then
ClrHome
Disp ""
Disp ""
Disp ""
Stop
Else
Goto 0
Lbl 0
ClrHome
Disp "NUMBERS="
Input ":",A
Goto 1
Lbl 1
If Z=2
Then
Input ":",B
{A,B}→L₅
Goto 10
Else
If Z=3
Then
Input ":",B
Input ":",C
{A,B,C}→L₅
Goto 10
Else
If Z=4
Then
Input ":",B
Input ":",C
Input ":",D
{A,B,C,D}→L₅
Goto 10
Else
If Z=5
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
{A,B,C,D,E}→L₅
Goto 10
Else
If Z=6
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
{A,B,C,D,E,F}→L₅
Goto 10
Else
If Z=7
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
{A,B,C,D,E,F,G}→L₅
Goto 10
Else
If Z=8
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
{A,B,C,D,E,F,G,H}→L₅
Goto 10
Else
If Z=9
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
{A,B,C,D,E,F,G,H,I}→L₅
Goto 10
Else
If Z=10
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
{A,B,C,D,E,F,G,H,I,J}→L₅
Goto 10
Else
If Z=11
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
{A,B,C,D,E,F,G,H,I,J,K}→L₅
Goto 10
Else
If Z=12
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
Input ":",L
{A,B,C,D,E,F,G,H,I,J,K,L}→L₅
Goto 10
Else
If Z=13
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
Input ":",L
Input ":",M
{A,B,C,D,E,F,G,H,I,J,K,L,M}→L₅
Goto 10
Else
If Z=14
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
Input ":",L
Input ":",M
Input ":",N
{A,B,C,D,E,F,G,H,I,J,K,L,M,N}→L₅
Goto 10
Else
If Z=15
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
Input ":",L
Input ":",M
Input ":",N
Input ":",O
{A,B,C,D,E,F,G,H,I,J,K,L,M,N,O}→L₅
Goto 10
Else
If Z=16
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
Input ":",L
Input ":",M
Input ":",N
Input ":",O
Input ":",P
{A,B,C,D,E,F,G,H,I,J,K,L,M,N,O,P}→L₅
Goto 10
Else
If Z=17
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
Input ":",L
Input ":",M
Input ":",N
Input ":",O
Input ":",P
Input ":",Q
{A,B,C,D,E,F,G,H,I,J,K,L,M,N,O,P,Q}→L₅
Goto 10
Else
If Z=18
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
Input ":",L
Input ":",M
Input ":",N
Input ":",O
Input ":",P
Input ":",Q
Input ":",R
{A,B,C,D,E,F,G,H,I,J,K,L,M,N,O,P,Q,R}→L₅
Goto 10
Else
If Z=19
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
Input ":",L
Input ":",M
Input ":",N
Input ":",O
Input ":",P
Input ":",Q
Input ":",R
Input ":",S
{A,B,C,D,E,F,G,H,I,J,K,L,M,N,O,P,Q,R,S}→L₅
Goto 10
Else
If Z=20
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
Input ":",L
Input ":",M
Input ":",N
Input ":",O
Input ":",P
Input ":",Q
Input ":",R
Input ":",S
Input ":",T
{A,B,C,D,E,F,G,H,I,J,K,L,M,N,O,P,Q,R,S,T}→L₅
Goto 10
Else
If Z=21
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
Input ":",L
Input ":",M
Input ":",N
Input ":",O
Input ":",P
Input ":",Q
Input ":",R
Input ":",S
Input ":",T
Input ":",U
{A,B,C,D,E,F,G,H,I,J,K,L,M,N,O,P,Q,R,S,T,U}→L₅
Goto 10
Else
If Z=22
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
Input ":",L
Input ":",M
Input ":",N
Input ":",O
Input ":",P
Input ":",Q
Input ":",R
Input ":",S
Input ":",T
Input ":",U
Input ":",V
{A,B,C,D,E,F,G,H,I,J,K,L,M,N,O,P,Q,R,S,T,U,V}→L₅
Goto 10
Else
If Z=23
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
Input ":",L
Input ":",M
Input ":",N
Input ":",O
Input ":",P
Input ":",Q
Input ":",R
Input ":",S
Input ":",T
Input ":",U
Input ":",V
Input ":",W
{A,B,C,D,E,F,G,H,I,J,K,L,M,N,O,P,Q,R,S,T,U,V,W}→L₅
Goto 10
Else
If Z=24
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
Input ":",L
Input ":",M
Input ":",N
Input ":",O
Input ":",P
Input ":",Q
Input ":",R
Input ":",S
Input ":",T
Input ":",U
Input ":",V
Input ":",W
Input ":",X
{A,B,C,D,E,F,G,H,I,J,K,L,M,N,O,P,Q,R,S,T,U,V,W,X}→L₅
Goto 10
Else
If Z=25
Then
Input ":",B
Input ":",C
Input ":",D
Input ":",E
Input ":",F
Input ":",G
Input ":",H
Input ":",I
Input ":",J
Input ":",K
Input ":",L
Input ":",M
Input ":",N
Input ":",O
Input ":",P
Input ":",Q
Input ":",R
Input ":",S
Input ":",T
Input ":",U
Input ":",V
Input ":",W
Input ":",X
Input ":",Y
{A,B,C,D,E,F,G,H,I,J,K,L,M,N,O,P,Q,R,S,T,U,V,W,X,Y}→L₅
Goto 10
Else
ClrHome
Disp ""
Disp ""
Disp ""
Stop
Lbl 10
ClrHome
Menu("FUNCTIONS","MEAN / AVERAGE",11,"MEDIAN",12,"MODE",13,"ARRANGE",14,"EXIT",99)
Lbl 11
mean(L₅)→Z
ClrHome
Output(1,1,"MEAN / AVERAGE=")
Output(3,6,round(Z,4))
Pause
Goto 10
Lbl 12
median(L₅)→Z
ClrHome
Output(2,2,"MEDIAN=")
Output(2,10,round(Z,4))
Pause
Goto 10
Lbl 13
ClrHome
Disp "MODE= MOST"
Disp "OCCURRING NUMBER"
SortA(L₅)
Output(4,1,L₅)
Pause
Goto 10
Lbl 14
ClrHome
Menu("ARRANGE BY::","ASCENDING",15,"DESCENDING",16,"RETURN",17,"EXIT",99)
Lbl 15
ClrHome
SortA(L₅)
Output(1,1,L₅)
Pause
Goto 10
Lbl 16
ClrHome
SortD(L₅)
Output(1,1,L₅)
Pause
Goto 10
Lbl 17
Goto 10
Lbl 99
Stop
5. 2254 KB
Float
ClrHome
Lbl 0
Menu("FUNCTIONS","EQUATION",1,"CIRCUMFERENCE",2,"AREA",3,"ARC LENGTH",4,"SECTOR AREA",5,"EXIT",99)
Lbl 1
Input "CENTER (X)=",H
Input "ENTER (Y)=",K
Input "RADIUS=",R
ClrHome
Disp "(X-H)²+(Y-K)²=R²
Disp ""
Disp ""
Disp ""
Output(3,4,"H=")
Output(3,7,H)
Output(4,4,"K=")
Output(4,7,K)
Output(3,10,"R=")
Output(3,13,R)
Stop
Lbl 2
Input "RADIUS=",R
ClrHome
Disp " CIRCUMFERENCE="
Disp ""
Disp ""
Disp ""
Disp ""
Output(3,4,"π*"
Output(3,6,round(2R,4))
Output(3,10,"UNITS")
Output(4,8,"OR")
Output(5,6,round(2πR,4)
Stop
Lbl 3
Input "RADIUS=",R
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(1,1,"AREA=")
Output(3,2,"π*")
Output(3,4,round(R²,4))
Output(4,3,"OR")
Output(5,2,round(πR²,4))
Stop
Lbl 4
ClrHome
Menu("ANGLE UNIT","DEGREES",7,"RADIANS",8,"PERCENT",11,"FRACTION",12,"BACK",9,"EXIT",99)
Lbl 7
Degree
Input "ANGLE=",A
Disp ""
Input "RADIUS=",R
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(2,3,"ARC LENGTH=")
Output(1,1,"*NOT SIMPLIFIED*")
Output(3,1,"π*")
Output(3,3,2AR)
Output(3,8,"/360")
Output(4,4,"OR")
Output(5,1,round(2πRA/360,4))
Output(5,12,"UNITS")
Stop
Lbl 8
Radian
Input "ANGLE=",A
A/π→A
Disp ""
Input "RADIUS=",R
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(1,3,"ARC LENGTH=")
Output(3,1,"π*")
Output(3,3,round(AR,2))
Output(4,4,"OR")
Output(5,1,round(πAR,4))
Degree
Stop
Lbl 11
ClrHome
Disp "PERCENT OF"
Input "CIRCLE=",A
Disp ""
Input "RADIUS=",R
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(3,1,"π*π)
Output(3,8,"/50")
Output(4,4,"OR")
Output(5,1,round(πAR/50,4))
Stop
Lbl 12
ClrHome
Disp "FRACTION OF"
Input "CIRCLE=",A
Disp ""
Input "RADIUS=",R
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(3,1,"π*")
Output(3,3,round(2AR,4))
Output(4,4,"OR")
Output(5,1,round(2πAR,4))
Stop
Lbl 9
Goto 0
Lbl 5
Menu("ANGLE UNIT","DEGREES",13,"RADIANS",14,"PERCENT",15,"FRACTION",16,"BACK",9,"EXIT",99)
Lbl 13
Degree
ClrHome
Input "ANGLE=",A
Disp ""
Input "RADIUS=",R
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(2,1,"AREA OF SECTOR=")
Output(3,1,"π*")
Output(3,3,round(AR²,2))
Output(3,7,"/360")
Output(4,4,"OR")
Output(5,1,round(AπR²/360,4)
Output(4,10,"SQUARED")
Stop
Lbl 14
Radian
Input "ANGLE=",A
A/π→A
Disp ""
Input "RADIUS=",R
ClrHome
Disp "*NOT SIMPLIFIED*"
Disp "AREA OF SECTOR="
Disp ""
Disp ""
Disp ""
Output(3,1,"π*")
Output(3,9,"/2")
Output(4,4,"OR")
Output(5,1,round(AπR²/2,4))
Degree
Stop
Lbl 15
ClrHome
Disp "PERCENT OF"
Input "CIRCLE=",A
Disp ""
Input "RADIUS=",R
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Output(3,1,"π*")
Output(3,3,AR²)
Output(3,9,"/100")
Output(4,4,"OR")
Output(5,1,round(πR²A/100,4)
Stop
Lbl 16
ClrHome
Disp "FRACTION OF"
Input "CIRCLE=",A
Disp ""
Input "RADIUS=",R
ClrHome
Disp ""
Disp ""
Disp ""
Disp ""
Disp ""
Output(1,1,"AREA OF SECTOR="
Output(3,1,"π*")
Output(3,3,round(AR²,4))
Output(4,4,"OR")
Output(5,1,round(AπR²,4)
Stop
Lbl 99
Stop
