Errr, I'm new to make, and I was wondering how do I force all the files "make" makes into a directory I made in root. I have tried looking this up but everything I found was beyond me. Hopefully someone will be able to put an explanation into layman terms.
What I want to do:
http://stackoverflow.com/questions/4102469/makefile-to-put-object-files-from-source-files-different-directories-into-a-sing
Can you link to the clergy explanation?
You have two options: use the same Makefile on different directories by running `make` in the directory where your source files are, and specifying a Makefile in another directory to `make`, or give a specifiable prefix to all of the source and object files in your Makefile. What are you looking to do, exactly?
What operating system is this on? Can't you just run make, then move all the files in the folder?
I am on windows, and yes I very much could, but I want the makefile to do this for me because I am making my own template for the c sdk that I am going to use with Atom. Atom calls a batch file called "build.bat" and that batch file makes a build folder. Then it calls make. I want make to put it's output in that build folder.
Put this in your build.bat
Code: @echo off
color 0F
:A
make clean
make
copy template.8xp build
make clean
pause
goto A
Code: @echo off
color 0F
:A
make clean
make
make clean
pause
goto A
That's great! Althought it is not in the makefile, I think it will do. I'll just spice it up a little and I'll be on my way.
