I'm trying to download some physics programs from this website (http://www.ticalc.org/pub/83plus/basic/science/physics/) but most of them don't work with the CE. Is there a way to edit their code to make it compatible?
PT_
- Site Admin (Posts: 2088)
- Re: How do I make TI-83/4 programs compatible with TI-84 CE?
- 02 Feb 2016 09:52:05 am
Almost all of the 83+ programs are compatible with the CE (not vice verca), so could you please say which programs?
Comparison
- CE: bigger graphscreen -> graphs no problem
- CE: bigger homescreen -> Output( no problem
- CE: more commands avaible -> no problem
- CE: not the fast circle routine (as far as I know) -> only remove that
- CE: larger graphscreen font -> You need to change the Text( coördinates.
Pure BASIC programs can all be ported. To edit a program: press [PRGM], [RIGHT] and select the program you want to edit. If you need to help, feel free to ask!
Btw, can you Introduce Yourself?
- EgyptianPrince
- Newbie (Posts: 4)
- 02 Feb 2016 10:16:10 am
Comparison
Thanks for the reply. Most of them didn't work. For example, in the list I linked to, there is a program called 83physicsplus. When I try to send it to my calculator, Ti-connect either gives me an error saying "could not communicate with the calculator" or "error 8C010001". A lot of them don't even transfer for me to edit the code.
That is not because of the fact the programs aren't compatible. Because the CE has a different processor (ez80 instead of z80), TI made a new TI-Connect for the CE, TI-Connect CE. Just download that program here and it should connect your calc to your pc. I hope this helps!
I honestly have no idea how to thank you enough. You probably just saved me from failing a full physics chapter. Thank you!
