Why does gossamer freeze my ti 84+ se??????
Can you be more specific? What globalCALCnet bridge are you using it with? I believe CLEAR is sufficient to close it if it is stuck on "Loading...".
gCn bridge wasnt problem. It seems to be that the calc has some sort of hardware problm. Gossamer, after 7 months of not working, came back to life and DID NOT CRASH my calc. This time clear closed it while running. No more problems. Will report in if problems appear. The bridge is the windows gcn client.
P.S. I think this gossamer situation is a direct result of a failure of the primary RAM page (calc using 2nd)
P.P.S Kerm, DCS and all software for it are great.
P.P.P.S. Head over to my post about my ROM problem.
I assume you mean this topic that you posted? I'd be very surprised if your calculator has a failed RAM chip and yet can still mostly operate.
Not totally failed. Primary page has only 300+ bytes left. Calc using 2nd page...
Calcsys mem bank readings:
Mem bank 1: 70 (very unusual)
Mem bank 2:129
Mem bank 2:129
Mem bank 2:129
I doubt it's a failed RAM page, and that a RAM page could only partially fail and have part of the page still work.
Mem bank 2:129
Have you seen these?
http://wikiti.brandonw.net/index.php?title=83Plus:OS:Ram_Pages
http://wikiti.brandonw.net/index.php?title=83Plus:Ports:06
http://wikiti.brandonw.net/index.php?title=83Plus:Ports:07
EDIT: Also, two days after you last posted here, you said that you re-sent your OS on this thread, and that it fixed some but not all of your calculator's problems. Have you tested Gossamer again to see if it works now?
This account is no longer active for the time being.
http://i.stack.imgur.com/TdrW7.gif
