Hi my name is Alex. I'm currently learning Java whilst also learning to program code on my calculator. Since my classes are heavily math based I am typically turning to my calculator for a lot of help and when I came across this website I realized I could use the source code 3 web application and found it be very useful. I've already made quite a few programs but they're buggy and not really the best since im still a newbie when it comes to programming.
Here's an example of one my programs for figuring out an equation with the Rydberg Constant
ClrHome
Disp "","****************","*  Programmed  *","*   By Alex    *","*   Capistran  *","****************",""
Pause
ClrHome
Disp "****************","Rydberg constant","= 2.18 x 10^~18J","AKA RH",""
Pause "****************"
ClrHome
(2.18*10^~18)->R
Disp "DeltaE=","Rh((1/n(i)^2)-","(1/n(f)^2))","N=Ni & Nf=M"
Pause "Press Enter"
ClrHome
Prompt N,M
abs((R((1/N^2)-(1/M^2))))->A
Disp A
Pause "Continue?"
Menu("","Yes",1,"No",2)
Lbl 1
(((3.00*10^8)(6.63*10^~34))/abs(A))->B
Disp B
Pause "Do you need NM?.."
Menu("","Yes",3,"No",2)
Lbl 3
int(abs((B/(1.00*10^~9))))->C
ClrHome
Normal
Disp C,"or"
Sci
C->H
Disp H,"Nanometers"
Stop
Lbl 2
Disp "Terminating..."
Stop
Disp A
Pause "Continue?"
can be
Menu("Continue?","Yes",1,"No")
And the same here:
Lbl 1
Menu("Do you need NM?","Yes",3,"No",2)
And here, this can be improved from:
Lbl 2
Stop
To:
Stop
Other than that, it looks good!
