When I turned my calculator on today, I was greeted with a completely screwn up screen. It showed some stuff that it shpuld show as far as I can see it but there is a lot of random pixels and lines above it.
I tried
It seems to work well except that the screen is screwn up and sometimes it RAM resets (or at least displays some parts of the screen).
I was able to create a program ABCD, see it in the mem menu and also edit it.
However, as I said, there is rubbish on the screen (Imagine you display a random buffer in Axe and display some stuff here and there which makes sense, it will look the same).
Edit:
The weirdest thing is I didn't play around with assembly. I have DCS 7.2 installed on TI-OS 1.19, if that helps.
What can I do? I have no computer here, though, and I will only come back home in a few days.
Oh, and I wish you all a happy new year!
I tried
- Turning off and on - no result at all
- RAM, Defaults and All Archive resets - lost everything I had on the calculator, I saw the bottom part of the MEM reset screen (the upper part was screwn up)
- Pulling out the batteries, pulling out the batteries and holding [del] - no results at all
Edit:
