Hey folks-
I've been getting back into doing some animated gifs in Imageready, and finished one for an anime series called 'No Game No Life'. I wanted to make it as small as possible, so instead of layering each change on the same image and saving it as a full image, then making it an animation layer, I just cut out the section of each image that I needed for the progression, used the eraser tool to remove all unneeded pixels, then layered the remainder in position, and set the whole animation to run over a common background (the static image). The final file works fine locally, and seems fine uploaded to Imgr, but when I upload it to CrunchyRoll (anime site), it shows the layer patches as white, instead of transparent.
Does anyone know why this would happen, and what I can do to avoid it in the future?
Here's the file as it is on Imgr:
Turned out pretty well, I think... but on CR, it looks like this (still animated, but hash):
Any suggestions would be appreciated...
