What is the smallest or fastest way to return the index of a list, where the number is ~2, starting from the index of A?
So
A=2, L1 = {~1,7,~2,1,~1,6,~2}
would return 3
and
A=5, L1 = {~1,7,~2,1,~1,6,~2}
would return 7
You can use this to find the index, where N is the number to search for, and A is the starting index:
A+sum(not(cumSum(N=seq(L1(X),X,A,dim(L1
If you are going to run this many times, replace X with [recursiven].
Here is a routine without seq( to return the first instance of N starting from A. Since it computes the entire list, it will be slower when A is close to dim(L1 and both are large.
cumSum(1 or L1
min(Ans+ᴇ9(Ans<A or N≠L1
Thanks to jonbush for fixing
cumSum(1 or L1
min(E9(Ans<A)+Ans*(N=L1
This is almost correct. The code below should work properly:
cumSum(1 or L1
min(E9(Ans<A or N!=L1)+Ans
