I was using the following code to check if a list is 0:
1 -> M
Repeat not( sum( fPart( listOP1 * M )))
M+1 -> M
Yet this obviously breaks if the sum of the list is 0, but the terms individually might not be. Is there a simple way, short of looping every list item, to see if the list values are all 0?
Yes.
If not(sum(abs(L1
Disp "ALL ELEMENTS ARE 0
If prod(not(L1
PT_ wrote:
If prod(not(L1
Very clever, that works as well. Smile
Ah, forgot about abs(). This is a fix for my polynomials program. Didn't realize rational zeroes test doesnt work on non-integer coefficients, so just converting all coefficients to integers. Smile
Edit: So prod( not( fPart( List ))) ?
The correct idiom is
min(not(fPart([list]
It's faster.
I presume you're using some form of Euclidean Algorithm to find the gcd and convert coefficients to integers?
