Lately, I have been storing stuff to strings. For example, for my Battleship game, it stores "CARRIER BATTLESHIPCRUISER SUBMARINE SPEEDBOAT " to Str1. But when I have Str1 disp on the homescreen, it only goes to "CARRIER BATTLESHIPCRUISER ". This isn't causing any problems, but any ideas on this anomaly and why it popped up?
Because Disp doesn't wrap? Try Output(1,1, and see if that doesn't help, or you need to use sub( and a loop to display each section of the string.
But the "CARRIER .... SER" goes past the edge of the homescreen. I can scroll to the end, but that is all it will go to.
Wait, ar you siplaying this in a program or on the homescreen you use for math equations? Because I am pretty sure that you can't scroll in a program...
On the homescreen.
You can. If you use the Pause command, you can scroll lists, matrices, and strings:
Pause "THIS IS A REALLY LONG STRING THAT GOES PAST THE EDGE OF THE SCREEN
Pause L1
Pause [A]
Pause Str1
Oh, I didn't know that. Razz
I didn't either. Thanks, Kerm!
