I am having trouble typing something in Ti-83+/Ti-84+ Basic. The problem is that whenever I use the Disp command and enter in "pi", it will spit out a π, not "pi". Does anyone know of a way to fix this?
Edit: Also, I am using the SourceCoder here on this site.
For starters, if you are requesting help (in this case, sourcecoder assistance) you should post in the sourcecoder subforum, not in the your projects subforum.
Second of all, type p/i to get the letters to work.
It's actually a backslash.
In SourceCoder (and TokenIDE, for that matter), putting a backslash in forces the IDE to put a token boundary there, which separates what otherwise would be the token "pi" into two separate tokens, "p" and "i".
