I have this code/program which displays the possible factors of a given value:
:0->dim(L1
:Prompt N
:For(I,1,sqrt(N
:If not(fPart(N/I
:N/I+I.01->L1(1+dim(L1
:End
:For(I,1,dim(L1
:{0,1->L2
:{0,L1(I->L3
:LinReg(ax+b) L2,L3,Y1
:Equ>String(Y1,Str1
:inString(Str1,".
:Disp sub(sub(Str1,1,Ans-1)+" * "+sub(Str1,Ans+1,length(Str1)-Ans),1,length(Str1)-1
:End
Is their a way to remove the zeros?…
For example, if the answer is displayed:
N=?96
96 * 01
48 * 02
32 * 03
24 * 04
16 * 06
12 * 08
Done
I want it to be displayed as:
N=?96
96 * 1
48 * 2
32 * 3
24 * 4
16 * 6
12 * 8
Done
I'm still working on the question you asked, but as a side note, on line 7, you have "length(L1" where you mean "dim(L1"
Yes it is "dim(L1"
Whoops...
Have you tried the Fix1 setting? That might solve your problem.
Akon: I replied to you on TI-BD here. I provided code that does the same thing that you want.
Problem Solved on http://tibasicdev.wikidot.com/forum/t-1116724/please-help-me-to-create-a-ti-calc-program
Thread Closed...
