I think this xLIBC function is what you're after: http://dcs.cemetech.net/index.php/DCSE:BasicLibs:DrawSprite#DrawSpriteTileBGA_.28TIOS_Values.29
This draws a small section of the tilemap as required (to restore a map after drawing a sprite).
PT_ wrote:
and what i have said in another post: how can i draw only 1 or 2 tiles of the tilemap, at the place where the sprite was?
but tanx!@!!!!
Since you already have your sprites loaded into memory (via real(5,0,0)), you can use the DrawSprite functions to draw single sprites (or a few sprites) into the GRAM. Does that make sense, or would you like me to elaborate further?
Edit: I didn't see tr1p1ea's post on the second page. My mistake.
oke, now i have this code:
"98423106540854620132125665409460"->Str8 //Random
real(0,1,1,0)
real(3,0,0,0,20,8,0,0,19,14,1
real(3,0,0,0,20,8,0,0,19,14,0
"HARDEST"
real(5,0,0)
real(1,1,0,80)
real(1,1,1,56)
real(1,1,2,80)
real(1,1,3,56)
Repeat real(2,0,0)=15
real(4,4,real(1,0,2),real(1,0,3),2,2,0,0,1,0,20,8)
real(4,1,0,1,1,1,0,0,255,1,0,0)
real(1,1,2,real(1,0,0))
real(1,1,3,real(1,0,1))
real(2,2,0,1,2,2)
real(0,3,4,255,1)
real(0,3,4,255,0)
real(0,1,0,1)
but when i move with my sprite, sometimes on the screen is a little black line flickering. how can i solve it?[/code]
There are 2 things that could affect it.
The first is that you are drawing the tilemap *before* loading any graphics data into memory. Now 1st run will result in random graphics, if nothing is changed and you run it a 2nd time the graphics should be loaded so could be alright. But still id move the lines around:
"HARDEST"
real(5,0,0)
The issue with the sprite drawing is that you have the sprite clearing around the wrong way. You are clearing the sprite on the *current* frame, but then redrawing over it with the updated position. This could lead to an overlap when updating the screen.
Try swapping these 2 lines:
See if that works.
*bump**bump**bump*
and something like this, why this will not work?
real(2,3,0,1,1,1,5,8,8,10,10,160,100)
my sprite cant move now and it is in the middle of the screen
Page 2 of 2
