Elements in list code for different textures, etc, and when the program encounters an instance of X in the list it draws said texture.
jpez wrote:
Darn, I wish had seen this topic earlier. Very impressive, kirb!
Pretty 1337, no? Do you agree these should go in the guide? -
calc84maniac
- eZ80 Guru (Posts: 1630)
- 01 Aug 2006 01:13:34 pm
- Last edited by calc84maniac on 24 Aug 2006 03:41:18 pm; edited 1 time in total
A small routine that returns how many times k is in L:
sum(k=L
Simple, eh?
sum(k=L
Simple, eh?
We were talking about something similiar to this at TIFW. If you want to see if a number is in a list, you can simply do max(K=L . You can also do max(K={24,25,26,34} and A=/={0,0,96,64 to check for multiple conditionals (ie If the user pressed left and A does not equal the left bounds of its movement).
Ooooh, this could be excellent for saving space. What it wouldn't be good for is speeding up the program; lists are notoriously slow to process.
- tifreak8x
- Guru (Posts: 11012)
- 01 Aug 2006 02:58:00 pm
- Last edited by tifreak8x on 01 Aug 2006 03:19:34 pm; edited 1 time in total
Kerm, I use this to detect if the arrow keys are pressed, and barely notice any lag. Since I do the more complex A-(K=etc stuff, I use:
If max(K={24,25,26,34:CODE TO CLEAR CHARACTER
Maybe you should take a closer look at the 1337 section on my forums...
Perhaps I should do so; if you've got more stuff like this there, it could be quite the valuable resource. Come to think of it, I believe SC2 does that optimization...
you should, we have quite a few interesting discussions on there, using Max, gragh databases, and well, just a bunch of other odd things not many people know about.
Yep. There are also many skilled programmers over there so you get some nice discussions and great optimizations when a new routine is presented. I used to use sum( but found out at TIFW that max( is faster. If you check the code to the Mario platformer I made, it uses max( frequently as a short way of saying If A=1 and B=1 or A=2 and B=2 etc.
tifreak8x wrote:
Uh, let's not and say we did, k?
Or we could do so and say we didn't, or even do so and say we did! Heh, I won't take you over for now.... or will I?!? 0x5.
Page 2 of 3
