How Is it possible to rezise the grid behind the graphs so it's 1x1 instead of 10x10?
So many things first:
- Welcome to Cemetech!
- Wrong topic; but I've split this topic for you already.
- What Calculator?
- In what aspect are you trying to accomplish this? (Graphing? Programing?)
- Any other info we may need to know?
You could try changing your Δx and Δy values, which can be found either in the Window menu or under VARS and then the sub menu Window. This should work in theory.
My issue with this, though: Wouldn't it be near impossible to see your graph if you did this? I mean, 1 pixel squares! Some would be filled in, others wouldn't! What if the graph suddenly changes direction???
But, then again, I'm assuming it IS monochrome...
The 84+CSE would be different (I think).
