I have a ti-83+ which recently has been acting quite strangely. Every time I press a button, especially the clear and delete buttons, the screen starts filling up with random garbage and after a few minutes it gets impossible to do anything. Can anyone think why this is happening and, if possible, how to fix it?
This recently happened to one of my classmates. The weird thing is, the problem fixed itself, for the most part, after a week or so. All the remaining bugs were solved by resetting all RAM and Archive memory.
Hello ThatGuy, and welcome to Cemetech! If you haven't already, try taking a look at this link:
http://www.cemetech.net/forum/viewtopic.php?t=5622
And see if one of those fixes will fix your problem. If need be, you may try re-installing your OS, which is also covered in the link. Good luck!
Thanks for all the help guys! Going to try what it says in the link but first i need a new graph link cable.
- KermMartian
- Site Admin (Posts: 64080)
- 22 Sep 2014 06:57:52 pm
- Last edited by KermMartian on 22 Sep 2014 07:22:06 pm; edited 1 time in total
What you are describing sounds like classic ribbon cable failure. Since it's a TI-83+, you should try replacing the ribbon cable with soldered wires as described in this topic: On the Repair of TI-83+ LCDs. Do you have soldering experience? - CVSoft
- Expert (Posts: 676)
- 22 Sep 2014 07:17:41 pm
- Last edited by CVSoft on 22 Sep 2014 07:23:56 pm; edited 1 time in total
What you are describing sounds like classic ribbon cable failure. Since it's a TI-83+, you should try replacing the ribbon cable with soldered wires as described in that topic. Do you have soldering experience?Since this involves modifying the internal hardware of the calculator, other potential causes should be ruled out (mainly by following as many of the steps in the article Mateo linked as possible). In the event that a ribbon cable repair is necessary, conductive ink pens such as CircuitWriter allow for repairs to be made without soldering; however, the longevity that soldering provides cannot be guaranteed. The calculator I repaired using CircuitWriter has lasted over a year, and is still in use at my high school.
I agree. However, I'd probably give him these abbreviated steps:
1) Turn on calculator. Verify corrupted-looking LCD.
2) Use TI-Connect to take a screenshot. Make sure it looks normal (ie, uncorrupted, different from the image on the screen).
3) If it is uncorrupted, replace the ribbon cable, a la http://www.cemetech.net/forum/viewtopic.php?t=5161 .
Thanks for all the help! Going to try what everyone said and hopefully everything will work out. Good thing I also have a ti-84+ and nspire cx to fall back on!
