AxeDCS Token XML file [TokenIDE]
The axiom, AxeDCS, allows one to use assembly references directly from DoorsCS in your Axe programs. You will need DoorsCS 7.1.1 at least to compile and run the program, and Axe 1.2.0 at least to compile.
This xml file is a token file for TokenIDE, allowing you to write axe programs with the DCS axiom and correct syntax.
AxeTokensDCS.xml | 51.3 KB |
README.txt | 147 bytes |
- 8.7 KB
- http://ceme.tech/DL922
- Authors
- 10/10 (1 vote)
- AxeDCS Token XML file [TokenIDE] (published 11 years, 9 months ago; 2013-08-05 13:35 UTC)
