This incredible program lets you graph 3D equations on your TI-83+ with an incredible amount of accuracy! Uses your current window and format settings, so you can plot it any way you want. Now includes many additional features for interactivity. Includes TRACE function, which allows you to follow your graph in three dimensions. The Calc function works the same as the 2D built-in grapher's Calc function, allowing you to enter the X and Z value and calculating Y for you. The Settings menu lets you change the graph parameters from within the program. You can even press any key during graphing to pause or quit! This multifunction program is a must for any serious mathemetician, now ported to the TI-73. Check out the screenshots!
GRAPH3D.73p | 295 bytes |
EQU.73p | 77 bytes |
- 498 bytes
- http://ceme.tech/DL353
- KermMartian
- 15 years ago
- Graph 3D v2.0 (published 15 years ago; 2008-11-26 00:20 UTC)
