I couldn't find something that did this, so I made an image conversion program between TI-92 / V200 etc, and general image formats. It will convert correctly sized (max. 239 x 103 px) .jpg .png .bmp .tif .tga and .gif files using a conversion threshold slider into files readable by Ti-92 or V200. Also .wbm supported with direct conversion as they are always 1bpp bitmaps.
Drag files and drop onto .exe file or call from command prompt like: "i292ia2 faces.bmp".
The other side of the palindromic name is that it can convert .92i and .v2i images from calculators to .bmp and .png.
Please give this alpha version a try and let me know if it is working on your system or not.
Antivirus software on Windows 10 or higher may stall the program initially, they should let it go after a while, but if not, then you can add it to the exception list.
i292i Alpha/24.jpg | 51.5 KB |
i292i Alpha/45.png | 56.0 KB |
i292i Alpha/faces.bmp | 72.5 KB |
i292i Alpha/gr1.92i | 3.1 KB |
i292i Alpha/gr2.v2i | 3.1 KB |
i292i Alpha/hqdefault-3407140238.tif | 97.2 KB |
i292i Alpha/i292ia2.exe | 1.1 MB |
i292i Alpha/leo.tif | 97.4 KB |
i292i Alpha/Lines.wbm | 3.0 KB |
i292i Alpha/matches.gif | 16.3 KB |
i292i Alpha/Readme - i292i.txt | 2.2 KB |
i292i Alpha/Zeb.tga | 72.2 KB |
- 838.0 KB
- http://ceme.tech/DL2295
- matalog
- 1 year, 8 months ago
- 1292i - Alpha - Image conversion between common image formats and TI-92/V200 images (picvars) (published 1 year, 8 months ago; 2022-09-03 23:51 UTC)
