I have been working over the four days since I released Doors CS 5.6 Beta 1 to resolve the bug reports that came in to me. Based on member feedback, there were two major problems, one with a homescreen hook that mysteriously could not be uninstalled via the usual romcall, and the second from a peculiar anomaly whereby deleted folders would not automatically have their contents moved to the parent folder of the deleted folder as I had thought I had programmed it. The first bug was helped via some manual flag manipulation (thanks to The Tari for the idea), while the second was solved by realizing I was doing something in a manner three times as difficult as necessary. I also fixed several more minor bugs, and updated the Doors CS Bugtracker to indicate this progress. The issues I have resolved:
:: Deleting programs sometimes causes system instability (07/28/06)
:: Deleting folders - subfolders not moved to parent (07/28/06)
:: If you click on a folder to go into it, then rightclick to rename, you can rename the :: folder (07/27/06)
:: Unable to lock or archive folders (07/27/06) this is intentional. see above for rename fix
:: Execution of BASIC programs causes homescreen lockup (07/27/06)
manual.pdf | 126.5 KB |
TI-83/Professional/adcs_pro.83p | 4.5 KB |
TI-83/Professional/ZLOAD.83P | 507 bytes |
TI-83/Standard/adcs_standard.83p | 3.9 KB |
TI-83/Standard/ZLOAD.83P | 507 bytes |
TI-83+, TI-84+/dcs6.8xk | 43.8 KB |
readme.txt | 393 bytes |
- 123.5 KB
- http://ceme.tech/DL224
- KermMartian
- 15 years, 7 months ago
- Doors CS 5.6 Beta 2 (published 15 years, 7 months ago; 2008-04-26 16:14 UTC)
