Alien creatures have broken into the Jupiter headquarters and sabotaged all systems and hid bombs in different corners and angles, which can destroy the headquarters and the two adjoining buildings any moment. It all depends on you. As secret agent Jupiter Jumpman you have the speed and experience to cross the aliens' plans and thus defend the headquarters.
In this comprehensive platform game, the bombs have to be collected in 30 levels. At the same time some creatures as bats, birds or aliens, but also robots and missiles disturb you. Also, collecting the bombs is a bit tricky. Either traps are triggered, i.e. ropes, ladders or platform parts disappear or fall down, or in some levels they only appear by this. The name of the level kind of contains directly what will happen! Seen as that, everything that moves should be avoided.
v1.01
- added optimizations suggested by Lionel Debroux (thank you Lionel)
- corrected version string (V1.00 was released with the version string set to v0.95)
- corrected enemy collision detection (v1.00 was released with enemy collision detection unintentionally disabled)
- increased accuracy of bullet and collectable collision detection
Jumpman_89_v1.01/ExtGraph-b02b924/lib/readme.txt | 352 bytes |
Jumpman_89_v1.01/gfx/BIN2C.COM | 10.6 KB |
Jumpman_89_v1.01/gfx/j3.bin | 2.4 KB |
Jumpman_89_v1.01/gfx/j3.h | 12.8 KB |
Jumpman_89_v1.01/gfx/j7.bin | 576 bytes |
Jumpman_89_v1.01/gfx/j7.h | 3.1 KB |
Jumpman_89_v1.01/gfx/j8.bin | 448 bytes |
Jumpman_89_v1.01/gfx/j8.h | 1.7 KB |
Jumpman_89_v1.01/gfx/j9.bin | 512 bytes |
Jumpman_89_v1.01/gfx/j9.h | 2.7 KB |
Jumpman_89_v1.01/gfx/make j3.bat | 80 bytes |
Jumpman_89_v1.01/gfx/make j7.bat | 69 bytes |
Jumpman_89_v1.01/gfx/make j8.bat | 69 bytes |
Jumpman_89_v1.01/gfx/make j9.bat | 69 bytes |
Jumpman_89_v1.01/jm_bullets.c | 11.2 KB |
Jumpman_89_v1.01/jm_bullets.h | 1.8 KB |
Jumpman_89_v1.01/jm_collectables.c | 18.1 KB |
Jumpman_89_v1.01/jm_collectables.h | 1.7 KB |
Jumpman_89_v1.01/jm_enemies.c | 55.8 KB |
Jumpman_89_v1.01/jm_enemies.h | 4.2 KB |
Jumpman_89_v1.01/jm_graphics.c | 2.1 KB |
Jumpman_89_v1.01/jm_graphics.h | 1.4 KB |
Jumpman_89_v1.01/jm_jumpman.c | 27.6 KB |
Jumpman_89_v1.01/jm_jumpman.h | 2.4 KB |
Jumpman_89_v1.01/jm_levels.c | 10.1 KB |
Jumpman_89_v1.01/jm_levels.h | 6.6 KB |
Jumpman_89_v1.01/jm_moving_platforms.c | 13.2 KB |
Jumpman_89_v1.01/jm_moving_platforms.h | 2.1 KB |
Jumpman_89_v1.01/jm_objects.c | 3.3 KB |
Jumpman_89_v1.01/jm_objects.h | 9.7 KB |
Jumpman_89_v1.01/jm_pad_4.bin | 4 bytes |
Jumpman_89_v1.01/jm_platforms.c | 15.4 KB |
Jumpman_89_v1.01/jm_platforms.h | 1.2 KB |
Jumpman_89_v1.01/jm_scores.c | 7.0 KB |
Jumpman_89_v1.01/jm_scores.h | 1.2 KB |
Jumpman_89_v1.01/jm_timers.c | 2.3 KB |
Jumpman_89_v1.01/jm_timers.h | 1.2 KB |
Jumpman_89_v1.01/jm_titlescreen.c | 8.3 KB |
Jumpman_89_v1.01/jm_titlescreen.h | 1.1 KB |
Jumpman_89_v1.01/jm_utilities.c | 3.3 KB |
Jumpman_89_v1.01/jm_utilities.h | 2.2 KB |
Jumpman_89_v1.01/jumpman.89y | 22.0 KB |
Jumpman_89_v1.01/jumpman.89z | 1.1 KB |
Jumpman_89_v1.01/jumpman.tpr | 2.7 KB |
Jumpman_89_v1.01/levels/jm_adv.txt | 8 bytes |
Jumpman_89_v1.01/levels/jm_beg.txt | 8 bytes |
Jumpman_89_v1.01/levels/jm_gl.txt | 10 bytes |
Jumpman_89_v1.01/levels/jm_int.txt | 12 bytes |
Jumpman_89_v1.01/levels/jm_level_data.c | 110.5 KB |
Jumpman_89_v1.01/levels/jm_level_marker.txt | 4 bytes |
Jumpman_89_v1.01/levels/jm_levels.tpr | 1.3 KB |
Jumpman_89_v1.01/levels/jm_levels_make.bat | 916 bytes |
Jumpman_89_v1.01/levels/jm_pad_4.bin | 4 bytes |
Jumpman_89_v1.01/levels/jml1.89y | 2.3 KB |
Jumpman_89_v1.01/levels/jml2.89y | 3.1 KB |
Jumpman_89_v1.01/levels/jml3.89y | 3.6 KB |
Jumpman_89_v1.01/levels/jml4.89y | 8.2 KB |
Jumpman_89_v1.01/levels/ttbin2oth.exe | 8.5 KB |
Jumpman_89_v1.01/levels/ttpack.exe | 23.5 KB |
Jumpman_89_v1.01/readme.txt | 3.8 KB |
Jumpman_89_v1.01/screenshots/jm_dragons.gif | 48.2 KB |
Jumpman_89_v1.01/screenshots/jm_follow_the_leader.gif | 42.2 KB |
Jumpman_89_v1.01/screenshots/jm_hotfoot.gif | 20.6 KB |
Jumpman_89_v1.01/screenshots/jm_jungle.gif | 40.6 KB |
Jumpman_89_v1.01/screenshots/jm_look_out_below.gif | 26.2 KB |
Jumpman_89_v1.01/screenshots/jm_the_roost.gif | 56.1 KB |
Jumpman_89_v1.01/ttpack.exe | 23.5 KB |
Jumpman_89_v1.01/utils/asm/GraySetScreenColor_R.s | 1.9 KB |
Jumpman_89_v1.01/utils/asm/GraySingleSprite8_COLOR_R.s | 4.4 KB |
Jumpman_89_v1.01/utils/asm/IsVTI.s | 2.0 KB |
Jumpman_89_v1.01/utils/BasicTypes.h | 1.1 KB |
Jumpman_89_v1.01/utils/BasicUtils.c | 552 bytes |
Jumpman_89_v1.01/utils/BasicUtils.h | 721 bytes |
Jumpman_89_v1.01/utils/FileUtils.c | 12.2 KB |
Jumpman_89_v1.01/utils/FileUtils.h | 762 bytes |
Jumpman_89_v1.01/utils/FontUtils.c | 17.6 KB |
Jumpman_89_v1.01/utils/FontUtils.h | 1.3 KB |
Jumpman_89_v1.01/utils/GrayUtils.c | 3.1 KB |
Jumpman_89_v1.01/utils/GrayUtils.h | 2.2 KB |
Jumpman_89_v1.01/utils/KeyUtils.c | 11.2 KB |
Jumpman_89_v1.01/utils/KeyUtils.h | 2.2 KB |
Jumpman_89_v1.01/utils/TimeUtils.c | 1.8 KB |
Jumpman_89_v1.01/utils/TimeUtils.h | 630 bytes |
Jumpman_89_v1.01/utils/TrigUtils.c | 1.8 KB |
Jumpman_89_v1.01/utils/TrigUtils.h | 557 bytes |
- 361.6 KB
- http://ceme.tech/DL1673
- Ranman
- 6 years, 6 months ago
- Jumpman 89 (published 6 years, 6 months ago; 2017-11-11 16:34 UTC)
