Bolt Pattern
The program BOLTPAT will calculate a bolt pattern given:
X = center, X coordinate
Y = center, Y coordinate
N = number of bolts
D = diameter of the circle
No angle of rotation is assumed.
The OC-Distance between each bolt is calculated by calculating
the linear distance between neighboring bolts.
Output:
Each point where the bolt should be placed. In addition, the on-
center distance between bolts is displayed. Finally, each of the
coordinates will be presented in a list.
bolt pattern diagram.jpg | 10.1 KB |
BOLTPAT.hpprgm | 1.1 KB |
readme.txt | 922 bytes |
- 10.8 KB
- http://ceme.tech/DL1307
- EdPi314
- 8 years, 11 months ago
- 10/10 (1 vote)
- Bolt Pattern (published 8 years, 11 months ago; 2015-05-19 03:06 UTC)
