HP Prime Auto-Off Timeout Changer
  2. HP Prime Programs
This little program simply makes use of the TOff function – which doesn't appear in my toolbox Function Catalogue yet there is help for the function if you type TOff and then press the Help key.
I've included the program (in the zip file) in both native and text form;
AutoOff.hpprgm
AutoOff.txt
This was programmed on my HP Prime using Ver 20141203 Rev 6975. I don't know if it works with earlier versions.
Cheers,
Ant (aka Labrat)
Screenshot #5686 Screenshot #5687 Screenshot #5688
AutoOff; Check or Change HP Prime Inactivity Timeout Value/AutoOff Screenshot A.jpg 11.2 KB
AutoOff; Check or Change HP Prime Inactivity Timeout Value/AutoOff Screenshot B.jpg 6.4 KB
AutoOff; Check or Change HP Prime Inactivity Timeout Value/AutoOff.hpprgm 4.0 KB
AutoOff; Check or Change HP Prime Inactivity Timeout Value/AutoOff.txt 2.0 KB
AutoOff; Check or Change HP Prime Inactivity Timeout Value/AutoOff for HP Prime Description & Info'.pdf 216.6 KB
AutoOff; Check or Change HP Prime Inactivity Timeout Value/AutoOff Screenshot C.jpg 6.3 KB
226.9 KB
Labrat
10/10 (1 vote)
  1. HP Prime Auto-Off Timeout Changer (published 10 years, 6 months ago; 2015-04-28 13:20 UTC)
