Battleship
Play Battleship on your calculator! read the included readme for directions. This DOES NOT REQUIRE Doors CSE.
Screenshot #5580 Screenshot #5581 Screenshot #5582
readme.txt 1.2 KB
BATTLESH.8xp 1.3 KB
1.5 KB
Caleb_J
4/10 (1 vote)
Seems like it's a good game, but there are so many errors in the code (using the minus symbol instead of the negative symbol, spaces after lines, spelling out the TextColor() token [that may be SC3's fault, actually] and I'm not sure what sub(Str1,10U+1,10) is supposed to do, seeing as U turns out to be 5 and Str1 is much less than 50 characters) that it's unplayable. I'm sure it'll be fun to play if/when these errors are fixed, but until then, don't download unless you want to spend time debugging.
  1. Battleship (published 9 years, 9 months ago; 2015-09-16 21:18 UTC)
