- TI-84 Plus C Silver Edition BASIC Science Programs
Have you ever wanted a program give you the difference between a magnitude 1 earthquake and magnitude 10? Have science homework that requires difference from magnitude 1 to Infinite? Well this is the program for YOU! For know you need to put lowest number first and highest number second.
RICHTER SCALE.8xp | 700 bytes |
How to install.txt | 762 bytes |
- 1.2 KB
- http://ceme.tech/DL1044
- nitrohawk80
- 8 years, 7 months ago
- 6/10 (1 vote)
Visuals (1.5/2): Nothing too special. Personally I think the splashscreen is unnecessary and could be used without it.
Speed (1.5/2): Splashscreen does take away from it a little bit. Most else is fairly snappy.
Ease of Use (1/2): Can only go one way. Easy to enter two numbers.
Practicality (0.5/2): Not too useful. Someone with basic understanding of logarithmic scales would determine the calculations in their head.
Other (1.5/2): Support for going from higher magnitude to lower would be very beneficial.
Overall: (6/10)
- Richter Scale Counter (published 8 years, 7 months ago; 2015-09-17 20:40 UTC)
