Chipmaster wrote:
I'll try to download AIM (it comes for linux right?).
Get GAIM instead. (if you can)
Or, if you don't want to download anything, you can use gmail's built in google talk if you enabled that feature. I have my GAIM setup to use my google talk, so just go to gaim.com, log in, and if you have the google talk feature enabled, you should be able to add me to your list and message me
I tried to follow the install instructions for AIM for Linux as best I could for a good 15minutes but I haven't gotten anywhere. Can somebody walk me through this. I'm following the instructions word for word, but for some reason it is not working.
This is what I am attempting to use. And I downloaded the one for "Other" OS's since Ubunutu was not mentioned in any other one.
For root permissions on Ubuntu "Breezy Badger" (5.10):
1. Press
ALT+F2(brings up a run menu)
2. Type
x-terminal-emulator
3. When the terminal comes up, type in
sudo passwd, and make the new password
passwd
4. Type
su and enter your password as
passwd
5. You are now root
(Note: I've recently used Ubuntu as a live cd for CLFS, and I promptly switched it out for another live cd; it's too a slow and there's really not much on it. A much more informative, yet still n00b-friendly distro would be Knoppix (as bloated as it is
Ultimate Dev'r wrote:
2. Type x-terminal-emulator
if that doesn't work type 'xterm' instead
EDIT: I KNOW! use www.meebo.com as your instant messenger! (don't forget to sign up for an AIM/yahoo/MSN account first) - it doesn't need to be downloaded or installed, yet is still quite decent
I was able to get myself logged in as root just fine. Everthing else is what I couldn't figure out
Edit: Kllrnohj: I'm on Meebo. My SN is disturbinglycool (don't ask why). What's yours?
Wait...i thought you couldn't get a root prompt?
OK, try this, go to ctrl-alt-Fx and for the login name type 'root' instead of 'patrick'. THEN do the 'apt-get update' and 'apt-get dist-upgrade'
SN's:see profile
I didn't know how to before. But I figured it out when the instructions told me to log in as "root".
hey nathan, I need to know what type of file system does the ubuntu linux use? I am using partition magic and need to know how to partition it correctly. please help.
-swivel
-swivel
look in the thread called something like install ubuntu linux. i discuss in great detail there how to use partition magic and how the partitions should be set up
You can install ubuntu to preety much any filesystem...however, I would recommend either reiserfs, ext3, or xfs.
i recommend resierfs
NTFS,FAT, FAT32, EXT2, EXT3, and LINUX Swap are the only ones available to make.
. And should there be a Drive letter or not? I heard that linux does'nt use letters but I need everyones preference
-swivel
Ext3 is the next best imho.
DANGIT Kerm! STOP POSTING HELP WHEN YOU HAVE NO IDEA WHAT IS GOING ON!!!!!
IF YOU WOULD HAVE DONE A SEARCH FOR "INSTALL UBUNTU LINUX" I WOULDN'T HAVE TO RETYPE THIS!!!
lazy SOB....
http://cemetech.net/forum/viewtopic.php?t=937&start=0#26423 <- READ THAT
Yeah, just shrink your partition and let Ubuntu format.
Click on the pic and please tell me what to do, elfprince is IMing me but I would like a non confusing two opions.
You should have already shrunk one of your hdd with Partition Magic, leaving some unformatted free space (like at least 15GB).
well, the DEMO kinda does'nt let you do anything and I dont know how to download it with out buying it again, I have a valid product key but I dont have the setup, heh. Kinda lost there.
-swivel
Ummm, read that other topic. And Kllrnohj, I _do_ know what I'm talking about. I mentioned our dilemma to one of the top Linux people at the top engineering school in the country (
) and he said Ext3 would be the next best option after reseirfs (sp?), since it's the most backwards compatible. He said that if an ext3 system is shut down stably, it's actually readable even as ext2 because the journalling is stored separately. So there.
