Hello everybody 🙂
I have uploaded at http://lpg.ticalc.org/prj_tiemu/downloads/setup.exe a pre-version of TIEmu 3.04 no-GDB, for beta-testing purposes 🙂
(*nix users can try http://lpg.ticalc.org/prj_tiemu/downloads/install_tiemu.sh, start by looking inside the script)
Since TIEmu 3.03, visible changes are fixes in the memory maps and I/O definitions, and fixes in the disassembler. Other changes, more visible to *nix users, include code updates not to use functions deprecated in recent GTK+ versions (2.20). Some updates to internal documentation, too. To sum up things, not much so far.
Before TIEmu 3.04 release, Thibault Duponchelle (a.k.a Contra / azerti, also working on TiLem-NG) and I are working to make TIEmu at least not crash anymore when loading on a 64-bit computer savestates created on a 32-bit computer, and vice-versa. With the ongoing switch to 64-bit computers, we'd better fix TIEmu somewhat before this known bug bites too many users 🙂
Note that transparently handling savestates created by buggy TIEmu versions is significantly harder than transparently handling images created by buggy TIEmu versions (which I contributed in 2009 to TIEmu, before becoming a (co-)maintainer, and is already available in TIEmu 3.03).
NOTE: thanks to updates of the shared libti* DLLs, as a side effect of installing this setup program for a beta TIEmu _after_ installing the beta TILP version featuring Jonimus' UI improvements (see another topic down this section), http://lpg.ticalc.org/prj_tilp/beta/setup.exe , you can get Nspire OS 2.x support in TILP, which I added last week-end by integrating (with minor changes) a patch contributed on the SF bug tracker.
The GDB-enabled version will follow later - I think it would be best to try bringing the huge (more than 120 KB !) NSIS definitions to a more manageable state first. NSIS does support wildcards, but there's no single wildcard in the TIEmu+GDB NSIS definitions created by Kevin, weird...
Thanks in advance for testing 😉
