- Casio prizm Mandelbrot explorer
- 22 Aug 2014 01:41:51 pm
- Last edited by ProgrammerNerd on 24 Apr 2021 01:44:11 am; edited 2 times in total
The Mandelbrot fractal is quite a sight.
Such wonder and amazement that can be found while viewing the Mandelbrot fractal can now be had on the Casio Prizm graphing calculator.
In addition this program can also be compiled for the PC assuming SDL is installed.
Just run make and it will be up and running.
There is very little difference in function between the PC version and the casio prizm version, the resolution is higher but that is it.
The controls are
Left, right, up, down moves the window in that direction
Menu key or ESC on the PC, exits to the menu or exits the program (PC)
F1 sets maximum iterations to 65535
F2 sets the maximum iterations to 224 (this is the default upon starting the program)
F3 toggles deep mode which is on by default. This means you can zoom in deeper with a slight performance hit.
I do not notice the difference
1 subtracts one from the maximum iterations
2 adds one to the maximum iterations
3 subtracts ten from the maximum iterations
4 adds ten to the maximum iterations
5 subtracts 100 from the maximum iterations
6 adds 100 to the maximum iterations
Shift zooms in
Alpha (ALT on PC) zooms out
Source code https://github.com/ComputerNerd/Mandelbrot-Casio-Prizm-Explorer
Binary https://github.com/ComputerNerd/Mandelbrot-Casio-Prizm-Explorer/blob/master/mandelbrot.g3a
Screen shots (from the PC version which gets very similar output differing only in resolution).
Anyway if you have any bug report(s), feature request(s), pull request(s), patch(es) or whatever relates to this I would be happy to hear about them.
The controls are
Shift zooms in
