- My Upcoming (first) Calculator Mod
- 30 Oct 2013 02:06:00 pm
- Last edited by BlackOnyx on 03 Nov 2013 03:28:35 pm; edited 1 time in total
OK, I know Ive been thinking about this for a LONG time, and never really got around to starting it, but I think its about time.
As I only have a TI-83 to do this on, that will have to be my subject. I dont have the money to justify tearing apart a new CSE or 84+SE for this.
Here are my ideas. Some I wont list, as I am going to make a couple of them be a surprise.
* Clear (fogged/etched) design cut/molded into the back and front of the case, and LED lit (unsure of colors at the moment)
* LCD backlighting (non-EL panel method)
* A speaker or two for audio/music/mp3 playback. Looks like I can get one from either an old GameBoy (which I have 8 of), or a small, generic MP3 player with one built in)
* Battery power level indicator (based on available voltage, IC driven) I was thinking about a small piece of PCB with 4 LEDs, and the 4-LED clear plastic light cover from the inside of a Sixaxis controller (that displays the controllers player designation) Pics of that piece are near impossible to find for some reason.
* Overclocking with switch (normal / overclock modes)
* Maybe replace battery with a larger capacity battery. I have a spare 5800 mAh external battery back. Should fit in the TI-83 with almost no issues, and still retain the backup battery location/mount.
* Paint job of some kind?
If you have any suggestions, or are willing to throw me some parts, that would be stellar. I dont have gobs of money for parts, so I just use what I have around the house.
UPDATE 11/3/2013:
I have finally taken the the TI-83 apart, and begun to size things up. Im checking for LED placement, MP3 player fitment, and places for switches. Nervous about breaking the LCD when I remove the backing from the actual glass part of the LCD itself. Oh well, I have ONE spare, so I should be good! I need to order one of the capacitors to OC the TI-83, a 33pf cap. If you have one, or a few, let me know. Also, need to do placement of the upgraded battery pack, but that will come after other mods are done. I have added a few new ideas for lighting to my list of mods, but will not post them yet. They are for you to find out when Im ready!
UPDATE 11/3/2013:
