So I've made a side scrolling program, but need help. with all the collision detection. I'll post the code layer if I need to.
supposing you are using the homescreen, and to display the level you are using a string, then "16(Y-1)+X" will return the String position from Y and X. this is used in my flamerman game.
if you are using ASM or Hybrid Libraries, then you'll likely be using a matrix/array. just check the contents of the matrix before placing something.
I didn't use y nor x
and where would.I.put that line? I have:
Output( 1,1,(sub(Str1,M,L)
Can you post the code you have at the moment? I need to see how you set everything up before I can help much.
ClrHome
"************************************************************************************************"→Str1
        *"→Str2
        *"→Str3
//Did this until i got to Str8
1→L
16→M
1→A
1→B
While 1
getKey→X
Output(1,1,(sub(Str1,L,M)) //Did this for Str1-Str8, row digit=str#
Output(A,B,"X
If X=24 and L≠1:Then
L-1→L
If X=25 and A≠2:Then
A-1→A
If X=34 and A≠8:Then
A+1→A
If X=36 and L≠50:Then //Just kind of guessed L since i left my calc at school...
L+1→L
This may be a bit incomplete, but this should (hopefully) enlighten any issues.
You seem to be creating a lot of duplicate threads with the same general idea. Please try to keep the number of threads you create low--if you can reuse a thread, please do. For example, you already have a thread for collision detection, and a thread for a side-scrolling game; you also have a thread called "Newbie questions" that also includes questions about collision detection. Please stop making superfluous threads.
