I have heard that there is a serial interface in the dock connector, and good way to tap into that?
There is indeed, but (I believe) without installing Ndless, there's not a lot that you can use that serial port for.
I do have that. Smile
In fact, this has been done in Lua, and it outputs sound through the serial port. But it was with another OS (I guess) and maybe the function that allowed to do that is no longer available. You might want to ask Nspire pros about that.
On OS 3.1, http://ti-pla.net/a4227 restores the Lua print() functionality, which TI needlessly removed and still hasn't put back to date (never will ?).
You are correct. It seems that the people deciding stuff think there may be security issues with allowing data to be send to the console. So yet another absolutely ridiculous idea from TI that only harms their users. I've had high hopes of it returning but well I was wrong. The education department is far too bloated to make proper decisions. HP is doing a much better job on that level.
Ok. But how do I get to it without any hardware changes to the calc?
Soldering on the calculator side (dock pins) is not necessary.
Then is the solution to find the mating connector (or a PCB) to mate to the dock connector, and solder onto that? I've also seen a solution that seemed to use a rubber band to tension wires against the dock connector.
One thing to keep in mind, though, is that if you accidentally touch the wrong pin on the serial port when doing certain connections, you can permanently damage your calculator. This happened to certain people who tried the sound programs.
Yep, could see that. Justneed a good way to do this...
What is the left port on the top?
AFAICT, nobody has found the mating connector, and we haven't heard of the person who wanted to provide a mating PCB.
Neither critor's method (which can be seen in a number of TI-Planet news items), nor mine, require rubber band. We just take advantage of the dock connector's lid to keep the wires / modified 2.54 mm connector in contact with the pads.
It's a proprietary connector for the Wireless cradle like here
(source https://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=119676 )
Ok then.
It wouldn't be too hard to etch it, I don't think.
I found the picture that I was thinking of: the rubber band was used to stabilize a USB to UART PCB on the back of the calculator, connected to the dock connector.
Finally got it!
[00]
Boot Loader Stage 1 (3.00.99)
Build: 2010/9/9, 17:29:13
Copyright (c) 2006-2010 Texas Instruments Incorporated
Using production keys
Last boot progress: 65
Available system memory: 33196
Checking for NAND: NAND Flash ID: Generic 1 GBit (0xA1)
SDRAM size: 64 MB
Fastboot[00]
SDRAM size: 64 MB
SDRAM memory test:   Pass
Clearing SDRAM...Done.
[00]
SDRAM size: 64 MB
Clocks:  CPU = 132MHz   AHB = 66MHz   APB = 33MHz
Boot option: Normal
Loading BOOT2 software...
0%
1%
2%
3%
4%
4%
5%
6%
7%
7%
8%
9%
10%
11%
11%
12%
13%
14%
15%
15%
16%
17%
18%
19%
19%
20%
21%
22%
24%
25%
27%
28%
30%
31%
33%
34%
36%
37%
39%
40%
42%
43%
45%
46%
48%
49%
51%
52%
54%
55%
57%
58%
60%
60%
61%
62%
63%
63%
64%
65%
66%
66%
67%
68%
69%
69%
70%
71%
72%
72%
73%
74%
75%
75%
76%
77%
78%
78%
79%
80%
80%
81%
82%
83%
83%
84%
85%
86%
86%
87%
88%
89%
89%
90%
91%
92%
92%
93%
94%
95%
95%
96%
97%
98%
98%
99%
BOOT1: loading complete (308 ticks), launching image.
[00]
Boot Loader Stage 2 (3.10.16)
Build: 2011/7/6, 14:38:40
Initializing graphics subsystem.
Boot option: Normal
Initializing filesystem.
Datalight Reliance v2.10.1150
Copyright (c) 2003-2006 Datalight, Inc.
Datalight FlashFX Pro v3.00 Build 1358
Nucleus Edition for ARM9
Copyright (c) 1993-2006 Datalight, Inc.
Patents: US#5860082, US#6260156.
Filesystem ready.
Purging temporary files...
TI_OS_INSTALL_PRECHECK_OK (0)
Loading Operating System...
0%
1%
2%
3%
4%
5%
6%
7%
8%
8%
9%
10%
11%
12%
13%
14%
15%
16%
17%
17%
18%
19%
20%
21%
22%
23%
23%
24%
25%
26%
27%
28%
29%
30%
30%
31%
32%
33%
34%
35%
36%
37%
38%
39%
39%
40%
41%
42%
43%
44%
45%
46%
47%
48%
48%
49%
50%
51%
52%
53%
54%
55%
56%
56%
57%
58%
59%
60%
61%
62%
63%
64%
65%
65%FlashFX: Correctable ECC error
66%
67%
68%
69%
70%
71%
72%
73%
73%
74%
75%
76%
77%
78%
79%
80%
81%
82%
82%
83%
84%
85%
86%
87%
88%
89%
90%
91%
91%
92%
93%
94%
95%
96%
97%
97%
98%
BOOT2: loading complete (1837 ticks), launching image.
[00]
Beginning system initialization.
Clocks:  CPU = 99 MHz AHB = 33 MHz APB = 16 MHz
Preparing file system. This takes a while...
   POSIX layer initialized.
   POSIX "NULL" device initialized.
   POSIX "CONSOLE" device initialized.
   POSIX file system initialized.
File system ready.
* No battery door detection
System build date: Aug 14 2011, 10:17:39
Available memory: 48666808 bytes
Launching system...
WLAN Module detached!
------------------ Module is Gone!!
TouchPad Firmware Revision : 01060000
Created Execution Context
RET - Echo UDP: TI_Echo_UDP_Init called +++
RET - ECHO UDP: EchoUDPListenerThread. Inside Thread +++
NavNet Ready.
Overwriting the buggy print function
startup-vpatch...
set version to  10.0.0.500
