So I decided that it would be a fun idea to put a different OS on my TI-83+.
I believe it was OS2.
I did this using the TI Connect Software for Windows.
The install completed, but now the calculator only displays the message "RAM cleared" and the block cursor in the top left.
The buttons are unresponsive.
The only way I've found to turn it off is to remove a battery.
After the battery is replaced, the screen remains blank until the ON key is pressed, but the same message is there.
TI Connect and TiLP (Windows) do not recognize the that the calculator is connected to the computer.
Is there any way to fix this, or is the calculator now bricked?
Thanks for any help you can give.
