So here is an irssi auto-word script I found, it can autocomplete any word in irc that has been said before, the trigger is the tab key. You need Perl to use it though. Install it to: ~/.irssi/scripts/autorun/
You can save it as anything.pl
The script:
The script:
#!/usr/bin/perl
use strict;
use warnings;
use Irssi;
# backlog completion:
# enter a word prefix and press TAB - and the prefix will be
# expanded from all the words on the current channel on everything
# that was said by yourself or by others - provided that its
# length is at least $backlog_complete_min_length and at most
# $backlog_complete_max_length long, and consists only of letters
# in $backlog_complete_word_chars. word case does not matter.
our $VERSION = '0.02';
our %IRSSI = (
authors => 'Florian Ragwitz',
contact => 'rafl@debian.org',
name => 'backlog completion',
description => 'backlog based tab completion',
license => 'GPL2',
url => 'http://perldition.org/',
changed => 'Mon Nov 06 23:42:05 CET 2006',
our $channel_history;
sub sig_message {
my ($server, $message) = @_;
my $target = pop;
my $min_length = Irssi::settings_get_int( 'backlog_complete_min_length' );
my $max_length = Irssi::settings_get_int( 'backlog_complete_max_length' );
my $max_words = Irssi::settings_get_int( 'backlog_complete_max_words' );
my $word_chars = Irssi::settings_get_str( 'backlog_complete_word_chars' );
my $server_id = $server->{address} .q{:}. $server->{port};
$channel_history->{ $server_id }->{ $target } ||= {};
my $queue = $channel_history->{ $server_id }->{ $target };
for my $word (split /[^$word_chars]/, $message) {
next if length $word < $min_length;
next if length $word > $max_length;
if (!exists $queue->{ $word }) {
$queue->{ $word } = { time => time(), count => 1 };
else {
$queue->{ $word }->{ count }++;
$queue->{ $word }->{ time } = time();
if (scalar keys %{ $queue } > $max_words) {
my $num_delete = $max_words - scalar keys %{ $queue };
if ($num_delete > 0) {
my @candidates = sort { $queue->{ $b }->{time} <=> $queue->{ $a }->{time} } keys %{ $queue };
delete $queue->{ pop @candidates } for 0 .. $num_delete;
sub sig_complete {
my ($complist, $window, $word, $linestart, $want_space) = @_;
my $order_by = Irssi::settings_get_str( 'backlog_complete_order_by' );
$order_by = 'count' if $order_by ne 'count' && $order_by ne 'time';
my $server = $window->{ active_server };
my $channel = $window->{ active };
return unless defined $server && defined $channel;
my $queue = $channel_history->{ $server_id }->{ $channel->{name} };
return unless $queue;
my $word_re = quotemeta ($word);
$word_re = qr/^$word_re/;
push @{ $complist },
sort { $queue->{ $b }->{ $order_by } <=> $queue->{ $a }->{ $order_by } }
grep { $_ =~ $word_re }
keys %{ $queue };
my %option_defaults = (
max_words => [ 'int', 1000 ],
min_length => [ 'int', 4 ],
max_length => [ 'int', 100 ],
word_chars => [ 'str', '\w' ],
order_by => [ 'str', 'time' ]
while (my ($option, $default_value) = each %option_defaults) {
my $func = 'Irssi::settings_add_'. $default_value->[0];
no strict 'refs';
$func->( 'backlog_complete', "backlog_complete_${option}", $default_value->[1] );
for my $signal ('message public', 'message private',
'message own_public', 'message own_private',
'message topic') {
Irssi::signal_add( $signal => \&sig_message );
Irssi::signal_add_last( 'complete word' => \&sig_complete );
