when I save my project as 8xp and transfer it to my calculator
It gives the message SE≥<degree is not a valid variable and I have to change it, has it something to do with Signing the App?
Thank You in Advance for Helping[/list]
It sounds like you gave your project a name that included symbols other than uppercase letters and numbers. Is that the case?
No, I gave it the Name "Snake"
Ohh... now I understand sorry. You're right I renamed it to "SNAKE" and it worked 😁
Glad to hear it. 🙂 The calculator doesn't work well with names with lowercase (although once you get the program on your calculator, you can use Doors CS to rename it). In the future, by the way, please edit your posts instead of double-posting, if it's within 24 hours of your previous post.
I have tried with the famous Quadratic equation, but how can I have fraction instead of decimal? or to have the two.
The easiest option is to use the ►Frac command, if it will work in your program. However, you've rather hijacked an unrelated thread; I recommend you start your own thread about this topic in the TI-BASIC subforum and also Introduce Yourself when you get a chance.
