*bump* I emailed you a new version, tifreak8x. I added a new bit to the flags to indicate when an EOF was hit at the start of the desired line, so that the Insert operation will work but the Replace operation will fail. I believe that insertion in the middle and at the end of files both work correctly. I also found what I think is an odd bug that should have shown up earlier (bytes disappearing off the end of programs when lines were inserted), but you told me you usually used Celtic 2 to read files.
I'll try to get a chance to add a sprite routine soon, if I can spare the cycles.
