Eh, if someone were to choose a black or dark square color, then the black pieces disappear :< I mean, I guess it could be done, but would it benefit anything?
So, I've implemented the custom board stuff that merthsoft suggested. Hopefully the menu aspect of it is intuitive enough.
http://tifreakware.net/tifreak8x/checkers/CHECKERS.8xp
Would be appreciative of anyone willing to throw that at their calculator, see what you all might think. Left/Right arrows change the colors, up/down arrows move the cursor, 2nd generates the board.
That looks great! And I see I still need to fix small rectangles of color arbitrarily not getting updated in screenshots, which is frustrating. I took a look at your code, and it seems that you don't prevent the user picking the same colors for Square 1/Square 2 or Player 1/Player 2. If I am correct in my reading of your code, is that something you might want to add, or does it fall under the heading of 'don't be dumb'?
Haha
I could possibly do that, wouldn't be horridly difficult to add in
I was tickled pink with the fact I was able to keep the Line( command just 1 line and still have it bounce between the two colors.
I'll see about adding that checker into the code tomorrow. Hopefully what you saw of my code wasn't too horridly unoptimized.
Nice job, that is a great way to handle it! What's next? Also, please nag me to fix that screenshotting code.
Next up is checkers generation and list setup. Once I get that done, I have to see how I want to do cursor stuff.
Edit:
Didn't realize it before, but the board is supposed to start with a dark panel, so I fixed that.
Now on to other things.
Edit:
What's the current state of affairs, tifreak8x? I don't mean to nag, just to keep you motivated that there are people interested in the progress of your projects. I know you have a busy life, so I understand if this is status quo.
For the last couple of days, I've sat and stared at the code and have gotten no where with checker generation. Not sure what is wrong, things just aren't clicking at the moment. Nothing else has really been done to the project since I added support for customized tiles and checkers.
Sorry to hear it; anything I can do to help? What do you mean about checker generation? Also, are you storing the checker positions in a list (like Connect4) or a matrix this time around?
I'm going with the list system. And I think what I'm doing with the lists was wrong, so I need to rewrite what I had written to match what Connect4 was, maybe that will be a bit less confusing.
And as to checker generation, the checkers can only be on certain fields, and they have to show up in their proper places at the start, etc. Just something I'll have to program around, which I think I can do now.
tifreak8x wrote:
The AI wouldn't be all that hard, I would think, but I could be wrong.
Famous last words of programmers.
Professor Jonathan Schaeffer, the definitive expert in checkers programming, wrote a book (One Jump Ahead) about his experiences in the field. The opening chapter is called "This Was Going To Be Easy." He spent the next two decades working on it. It turns out that checkers is a deceptive game in the the rules are easy, but the strategy is deep.
You might want to check out the Windows program CheckerBoard. Besides the incredibly strong default engine, it also comes with an engine called "Simple Checkers" along with free-to-use source code.
-wes
-wes
Though last I heard, Checkers is actually solved in the game-theoretic sense, as compared to Chess or Go which have a much larger outcome space.
Yes, Dr. Schaeffer and his team from U. of Alberta "solved" it in 2007. I suspect we're many decades (centuries?) away from solving chess.
Check out http://en.wikipedia.org/wiki/Solving_chess#Predictions_on_when.2Fif_chess_will_be_solved
Most people view checkers as a child's game, like swimming across a pond. Actually, it's more like trying to swim to The Bahamas. (Chess is like trying to swim around the world. )
-wes
-wes
And Go is like trying to swim to the moon
So, I was thinking about being able to move the cursor. Should I use the number pad to make it go diagonal, or should I just use the main arrows so it only goes 4 directions?
I'm going to try once again to get it to place the appropriate checkers on the board.
Edit:
Well, I've managed to get it to put checkers on the screen, just not in the right spots on the board. I need to rearrange my For( loops, and make changes to the positions of the checkers themselves.
I'll mess with it more tomorrow sometime. :/
Edit:
ClrDraw:AxesOff
GridOff
SetUpEditor L3
SetUpEditor L1
32->dim(L1
{2,2,2,2,2,2,2,2,2,2,2,2,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1->L1
{2,4,5,6,6,7,7,7->L3
BackgroundOff
0->Xmin:0->Ymin:1->I
264->Xmax:164->Ymax
11->S:23->T:11->U:12->V
1->W:7->A
TextColor(Red
Text(7,15,"Square 1: "
Text(27,15,"Square 2: "
Text(47,15,"Player 1: "
Text(67,15,"Player 2: "
Text(150,1,"2nd to proceed
While W=1
For(G,2,18,2
Line(88,140+G,88+18,140+G,1,S,2
For(G,2,18,2
Line(88,120+G,88+18,120+G,1,T,2
For(F,1,8
L3(F
Line(97-Ans,102+F,97+Ans,102+F,1,U,2
Line(97-Ans,16-F+102,97+Ans,16-F+102,1,U,2
For(F,1,8
L3(F
Line(97-Ans,82+F,97+Ans,82+F,1,V,2
Line(97-Ans,16-F+82,97+Ans,16-F+82,1,V,2
2->W:While W=2
getKey->K
Text(A,1,"|>
If K:Text(A,1,"
A-20((A>7 and K=25)-(A<67 and K=34->A
If K=24 or K=26:Then
If A=7:Then
S-1((S>10 and K=24)-(S<24 and K=26->S
For(G,2,18,2
End:End
If A=27:Then
T-1((T>10 and K=24)-(T<24 and K=26->T
For(G,2,18,2
End:End
If A=47:Then
U-1((U>10 and K=24)-(U<24 and K=26->U
For(F,1,8
L3(F
End:End
If A=67:Then
V-1((V>10 and K=24)-(V<24 and K=26->V
For(F,1,8
L3(F
End:End
If K=21:Then
If U!=T and V!=T and U!=V:3->W
If U=T or V=T or U=V:Then
TextColor(randInt(10,24
Text(90,1,"CHECKERS CANNOT BE THE SAME
Text(103,1,"AS SQUARE 2 OR EACHOTHER!
TextColor(11
End:End
End:End
ClrDraw
For(F,4,156,19
Line(7,F,167,F,1,12,1
For(F,7,167,20
Line(F,4,F,156,1,12,1
For(H,8,166,20
not(I->I
For(F,4,138,19
not(I->I
For(G,2,18,2
Line(H,F+G,H+18,F+G,1,S(I=0)+TI,2
End:End:End
5->theta
For(F,1,8
not(I->I
TextColor(11+I
Text(~1,theta,175,sub("CHECKERS",F,1
theta+20->theta
2->theta
Text(~1,75,205,"BY:
For(F,1,12
not(I->I
TextColor(11+I
Text(theta,254,sub("TI-FREAKWARE",F,1
theta+13->theta
1->I:1->G
For(J,4,138,19
not(I->I
For(H,166,8,~20-20I
not(I->I
For(F,1,8
L3(F
Line(J-Ans,(H-7)+F,J+Ans,(H-7)+F,1,U(L1(G)=1)+V(L1(G)=2),2
Line(J-Ans,16-F+(H-7),J+Ans,16-F+(H-7),1,U(L1(G)=1)+V(L1(G)=2),2
G+1->G
End:End
Page 2 of 5
