oh okay.
What are you taking a determinant of that is yielding zero? That sounds like a degenerate triangle and/or some inappropriately parallel lines. Are you sure the model contains only tris and no quads?
Yes, all quads. Here's the code in question. tri is a 3x3 array, rows are points, columns are [x, y, z]. Given a known x and y or x and z or y and z, it finds the missing point on the triangle, if possible.
    def geom_cart2bary(self,tri,x,y,z):
        P = array([x,y,z])
        if x == None:
            a = 1
            b = 2
            c = 0
        elif y == None:
            a = 0
            b = 2
            c = 1
        else:
            a = 0
            b = 1
            c = 2
        det = (tri[1,b]-tri[2,b])*(tri[0,a]-tri[2,a]) + \
              (tri[2,a]-tri[1,a])*(tri[0,b]-tri[2,b])
        if det == 0:        # Incoming div-by-0
            print("Determinant: Div-by-0 warning")
            return [0., 0., 0., x, y, z]
        # Compute barycentric coordinates
        l1 = ((tri[1,b]-tri[2,b])*(P[a]-tri[2,a]) + \
              (tri[2,a]-tri[1,a])*(P[b]-tri[2,b]))/det;
        l2 = ((tri[2,b]-tri[0,b])*(P[a]-tri[2,a]) + \
              (tri[0,a]-tri[2,a])*(P[b]-tri[2,b]))/det;
        l3 = 1. - l1 - l2
        rval = [l1, l2, l3, x, y, z]
        rval[3+c] = (l1*tri[0,c]) + (l2*tri[1,c]) + (l3*tri[2,c])
        return rval
can you give some example inputs producing success and failure modes?
Just to clarify: tri is a matrix of row vectors defining a triangle, and [x,y,z] are a barycentric coordinate triplet missing a coordinate?
Tri is a matrix of row vectors defining a triangle. [x, y, z] are cartesian coordinates missing one of the coordinates. The desired output is [l1, l2, l3, x, y, z], where x, y, and z are all filled, and l1, l2, and l3 are the barycentric lambda coordinates.
Sample success matrix:
[[  84.68746953   59.83120068  155.70715938]
 [  82.88576245   60.64850894  152.60306357]
 [  83.41658276   58.7063019   152.60306357]]
Sample failure matrix:
[[ 49.42879067  88.10337266  56.30088594]
 [ 57.97150024  83.39647856  56.89353193]
 [ 49.42879067  88.10337266  56.89353193]]
Notice that [0,0] = [2,0] and [0,1] = [2,1] (and because the z-axis span is the smallest, z will be the missing coordinate). This will make (tri[1,b]-tri[2,b])*(tri[0,a]-tri[2,a]) + (tri[2,a]-tri[1,a])*(tri[0,b]-tri[2,b]) of course be zero. And that will be true even if the triangle points get shuffled. What to do.
Edit: Unless I shuffle rows 1 and 2 in this case, I believe... That would give:
For which we get the det = (nonzero)*(nonzero) + (nonzero)*(nonzero). And I guess I can then just reshuffle the lambdas at the end.
Edit #2: Nope, although that makes the terms nonzero, it also makes the sum cancel out to zero. I should have expected it wasn't that easy.
What matrix are you trying to take the determinant of? Because that is almost certainly not the formula for a 3x3 determinant.
WabbitEmu agrees with me: I just plugged those in time to my calculator to do some determinant calculations and got nonzero results for the original, or the rowswapped version. Then I looked more closely at the formula and it doesn't appear to have the correct terms unless I'm really bad at mental algebra (it foils to 8 terms, not 6).
In this case, |tri| = -583.9326763.
[edit]
As a side note, the matrices would absolutely be singular if you swap only a[0,2] and a[2,2]. Are all of the triangles where you're having trouble right triangles where the 90° bend is along a primary axis?
[edit 2]
What happens if you replace your code with this:
        P = array([x,y,z])
        if x == None:
            a = 1
            b = 2
            c = 0
        elif y == None:
            a = 0
            b = 2
            c = 1
        else:
            a = 0
            b = 1
            c = 2
        det = numpy.lingalg.det(tri[:,array([a,b,c])])
        l3 = 1. - l1 - l2
        return rval
Also, how do you choose which columns to swap? I don't understand the progression from 1,2,0 to 0,2,1 to 0,1,2 ( I would have expected that middle list to be perhaps 2,0,1). Also also, swapping columns only effects the sign of the determinant since it's an alternating multilinear function (by rows or columns), so that makes me think you're calculating a determinant of some kind even if it's not actually the determinant of |tri| (it was scale-invariant under row swapping).
[edit 2]
Oh, I see, I think you're trying to take the determinant of
But I'm pretty sure you can't do that, because the barycentric coordinate formulation is given in terms of x and y only, so you need to calculate planar coordinates instead of just dropping a coordinate.
Let's adjust your matrix in the following manner:
# fiddle with this a bit more to choose the axises of rotation
# and proper indexing if/when
# the missing coordinate/smallest edge is not the third one
P = matrix([[x],[y],[z]])
trimatrix = matrix(tris).transpose()
offset = trimatrix[:,0]
centered = tris - offset # translate to origin
theta_x = atan2(centered[2,2],centered[1,2])
rx = matrix([[1,0,0],[0,cos(-theta_x),-sin(-theta_x)],[0,sin(-theta_x),cos(-theta_x)]])
intermediate1 = rx*centered
theta_z = atan2(intermediate1[1,2],intermediate1[0,2])
rz = matrix([[cos(-theta_z),-sin(-theta_z),0],[sin(-theta_z),cos(-theta_z),0],[0,0,1]])
theta_x2 = atan2(intermediate2[2,1],intermediate2[1,1])
rx2 = matrix([[1,0,0],[0,cos(-theta_x2),-sin(-theta_x2)],[0,sin(-theta_x2),cos(-theta_x2)]])
planar = rx2*intermediate2
Pplanar = rx2*rz*rx*(P-offset)
# Do something here to set tolerances
# and take care of rounding error, if it seems like it matters
T = matrix([[(planar[0,0]-planar[0,2]),(planar[0,1]-planar[0,2])],[(planar[1,0]-planar[1,2]),(planar[1,1]-planar[1,2])]])
det = numpy.linalg.det(T)
lam12 = inv(T) * (Pplanar[:2]-planar[:2,2])
lambda1 = lam12[0]
lambda2 = lam12[1]
lambda3 = 1 - lambda1 - lambda2
rval = [lambda1,lambda2,lambda3,x,y,lambda1*trimatrix[2,0]+lambda2*trimatrix[2,1]+lambda3*trimatrix[2,2]]
I'm computing the determinant of the T matrix as per this Wikipedia article. The problems do indeed seem to arise when there's a 90-degree bend along a primary axis. And I tried swapping rows, not columns.
I think if you mix the last codeblock I posted above with your values of a,b,c, and my reindexing trick it should work.
        if x == None:
            a = 1
            b = 2
            c = 0
        elif y == None:
            a = 0
            b = 2
            c = 1
        else:
            a = 0
            b = 1
            c = 2
reindex = array([a,b,c])
trimatrix = matrix(tris[reindex]).transpose()
#instead of trimatrix = matrix(tris).transpose()
P = matrix([[x],[y],[z]])[reindex]
#instead of P =matrix([[x],[y],[z]])
Will this take into account the fact that one of the variables is unknown? i.e., will it mind that one of x, y, and z is None, which in the P = line will turn one of those elements into a NaN?
that's what the reindexing in the previous codesnippet takes care of. It always puts the missing one in last place.
Gotcha, that makes sense. So the first problem I encounter with this (other than the missing intermediate2 that we worked out) is at Pplanar = rx2*rz*rx*(P-offset), where it complains about subtracting a float from a None. I resolved that by just setting P[2] to 0.0 all the time (in the hopes that since it's "unknown", its value doesn't matter), but I'm relatively sure that's not the correct solution. After that "fix", I get so many triangles the converter claims come out empty that I'm pretty sure something is wrong, but I also eventually get "TypeError: unsupported operand type(s) for -: 'NoneType' and 'numpy.int64'" in an operation that indicates lambda1*trimatrix[2,0]+lambda2*trimatrix[2,1]+lambda3*trimatrix[2,2] is coming out as None.
Also, doesn't the rval line require a remapping to reverse the coordinate remapping at the beginning?
hmmm, I'm afraid we need a proxy value to carry through in place of Z, and then solve some kind of equation at the end.
Let's do an experiment. Create this class:
class Unknown(object):
   def __init__(self,name,sterm=0,mterm=1):
      self.name = name
      self.reciprocal = False
      self.sterm=sterm
      self.mterm=mterm
   def __repr__(self):
      return "%s((%s*Unknown(%s))+sterm)" % ("1/" if self.reciprocal else "",repr(self.mterm),repr(self.name),repr(self.sterm))
   def __str__(self):
      return "((%s*%s)+sterm)" % ("1/" if self.reciprocal else "",str(self.mterm),str(self.name),str(self.sterm))
   def __mul__(self, other):
      self.sterm = self.sterm * other
      self.mterm = self.mterm * other
      return self
   def __div__(self, other):
      self.sterm = self.sterm / other
      self.mterm = self.mterm / other
      return self
   def __add__(self, other):
      self.sterm = self.sterm + other
      return self
   def __sub__(self, other):
      self.sterm = self.sterm - other
      return self
   def __rmul__(self, other):
      return self.__mul__(other)
   # Division is not commutative!
   def __rdiv__(self, other):
      self.reciprocal = not self.reciprocal
      return self.__div__(1/other)
   def __radd__(self, other):
      return self.__add__(other)
   # Subtraction is not commutative!
   def __rsub__(self, other):
      return self.__sub__(-other)
   def __neg__(self, other):
      return self.__mul__(-1)
Then do this after the initial setup
P[2] = Unknown("Z")
and then let fly, and print out the lambdas at the end and see what it gives you. I recommend using test data, not real data/not trying to write data output Wink
w.r.t the coordinate remapping, the lambdas should be spitting out in exactly the same fashion you had before, the x/y/z probably do need your
rval[3+c]
trick instead of how I set it up..
okay, so I've produced a patched Unknown class, and as far as I can tell, it works just fine with my numpy. I also noticed that the line which says
should be
trimatrix instead of tris
   def __init__(self,name,sterm=0,mterm=1,reciprocal=False):
      self.name = name
      self.reciprocal = reciprocal
      self.sterm=sterm
      self.mterm=mterm
   def __repr__(self):
      return "%s((%s*Unknown(%s))+%s)" % ("1./" if self.reciprocal else "",repr(self.mterm),repr(self.name),repr(self.sterm))
   def __str__(self):
      return "%s((%s*%s)+%s)" % ("1./" if self.reciprocal else "",str(self.mterm),str(self.name),str(self.sterm))
      oterm = (1./other) if self.reciprocal else other
      return Unknown(name=self.name,sterm=self.sterm*oterm,mterm=self.mterm*oterm,reciprocal=self.reciprocal)
      return self.__mul__(1./other)
      if self.reciprocal:
         # This is where it gets hairy
         denom = Unknown(name=self.name,sterm=self.sterm,mterm=self.mterm,reciprocal=True)
         return Unknown(name=self.name,sterm=(self.sterm*other+1)*denom,mterm=(self.mterm*other)*denom,reciprocal=False)
      else:
         return Unknown(name=self.name,sterm=self.sterm+other,mterm=self.mterm,reciprocal=False)
      return self
      return self.__add__(-other)
      return Unknown(name=self.name,sterm=self.sterm,mterm=self.mterm,reciprocal = not self.reciprocal).__rmul__(other)
      return self.__neg__().__radd__(other)
   def __neg__(self):
      return Unknown(name=self.name,sterm=-self.sterm,mterm=-self.mterm,reciprocal=self.reciprocal)
   def __call__(self, value):
      term = self.sterm + (self.mterm * value)
      return 1/term if self.reciprocal else term
The only tricky part is getting it to solve for itself, and that shouldn't actually be too hard since everything is linear.
Here's the result of my unit test:
>>> t = kmz2mc.Tri2Voxel(None)
>>> t.geom_prep([0, 0, 0],[100, 100, 100])
Reserving 101 x 101 x 101 array...
>>> tri
array([[ 93.7878877 ,  30.0793981 ,  56.30088594],
       [ 76.68651914,  34.28190747,  56.30088594],
       [ 78.89287129,  38.28630181,  56.30088594]])
>>> t.geom_cart2bary(tri, 80., 35., None)
[((-0.0*Unknown('Z'))+((-0.0*Unknown('Z'))+0.15027257070615613)), ((-0.0*Unknown('Z'))+((0.0*Unknown('Z'))+0.5126940849587779)), ((0.0*Unknown('Z'))+((0.0*Unknown('Z'))+((0.0*Unknown('Z'))+((-0.0*Unknown('Z'))+0.33703334433506604)))), 80.0, 35.0, ((-0*Unknown('Z'))+((-0*Unknown('Z'))+((-0*Unknown('Z'))+((0.0*Unknown('Z'))+((0.0*Unknown('Z'))+((0.0*Unknown('Z'))+((0.0*Unknown('Z'))+((-0*Unknown('Z'))+56.300885940000001))))))))]
Clearly the last two lines shouldn't be:
        rval = [lambda1,lambda2,lambda3,x,y,z]
        rval[3+c] = lambda1*trimatrix[2,0]+lambda2*trimatrix[2,1]+lambda3*trimatrix[2,2]
Looks good (last 2 lines included)! Just need to solve for dem Zs! I'll try to make a quick solver Smile
Yeah, I'm currently pondering it myself; just wanted to point out that everything is looking good. Smile I'm also trying to wrap my brain around this custom object with custom operators idea; this is new to me.
Edit: looks like lambda1-3 can at least just be lambda1.sterm.sterm..., but I guess I need an operator or method (float()?) that "simplifies" these Unknown objects, discarding the 0*name mterms.
I have a simplifier set up. Do you have scipy as well as numpy?
I do indeed; I even have it loaded, because pymclevel requires it.
Meet me back here in 15 minutes Smile
Will do! I'll investigate the thin-triangle issue in the meantime.
The solver works pretty well, though it will probably work better if you can pass in a reasonable guess at z.
Haven't tested the last couple lines with the returns - should work, but if it complains about broadcasting the function call with **try_solve in the arguments, you may have to make those assignments one at a time.
import scipy.optimize as scop
      self.name = name
      self.sterm=sterm
      self.mterm=mterm
   def __repr__(self):
   def __str__(self):
      if self.reciprocal:
      else:
      return self
   def __neg__(self):
   #Evaluate one level deep
   def __call__(self, **variables):
      tterm = Unknown(self.name)
      mdict = {}
      sdict = {}
      for n,v in variables.iteritems():
         if self.name == n:
            tterm = v
         if type(self.mterm) == Unknown and n in self.mterm:
            mdict[n] = v
         if type(self.sterm) == Unknown and n in self.sterm:
            sdict[n] = v
      term = (self.sterm(**sdict) if sdict else self.sterm) + (tterm * (self.mterm(**mdict) if mdict else self.mterm))
   def __contains__(self, key):
      ret = False
      if self.name == key:
         ret = True
      if type(self.mterm) == Unknown:
         ret |= self.mterm.__contains__(key)
      if type(self.sterm) == Unknown:
         ret |= self.sterm.__contains__(key)
      return ret
   def findaroot(self, **guesses):
      args = sorted(guesses.keys())
      init_vals = array([guesses[a] for a in args])
      def redict(argorder,values):
         return {a:v for a,v in zip(args,values)}
      def solvable(array_values):
         return self.__call__(**redict(args,array_values))
      def sstatus(x,f):
         print "Trying %s to get %f" % (str(x),self.__call__(**redict(args,x)))
      result = scop.root(solvable,init_vals,method='excitingmixing',tol=1e-10)
      if result.success:
         ret = redict(args,result.x)
      else:
         ret = {}
      return ret
if x == None:
   a = 1
   b = 2
   c = 0
elif y == None:
   a = 0
   b = 2
   c = 1
else:
   a = 0
   b = 1
   c = 2
P[2]=Unknown('z')
centered = trimatrix - offset # translate to origin
intermediate2=rz*intermediate1
lambda1 = lam12[0,0]
lambda2 = lam12[1,0]
rval = array([lambda1,lambda2,lambda3,x,y,z])
# feel free to put better guesses if you have them
# but it's linear so I think it should be okay?
try_solve = (rval[3+c] - P[2,0]).findaroot(z=0)
if try_solve:
    unsolved_indices = array([1,2,3,3+c])
    rval[unsolved_indices] = rval[unsolved_indices](**try_solve)
else:
    print "Found no solution to equation %s=0" % (str(rval[3+c] - P[2]))
return rval
Page 2 of 10
